AM auto fixed glass window, removed from my swb sliding door t6.1 fair condition, took my time with the wire during removal has old primer on it and I’ve removed most of the old bond. Also have an unopened tube of master bond, glass primer (used but still a lot in the bottle and very much alive)...
After suffering the classic VW flush fit window leaky horror stories that we all know about I took the plunge and decided to get a local reputable camper converters to install a pair of THQ new generation flush fit sliding windows. After feeling pretty happy that I'd seen the last of my...
I was just wondering if someone can tell me the pros and cons of sliding windows being flush or not. Is it just aesthetics or does one type leak less than another. We aren't bothered about being in stealth mode :) ?
TIA
Claire
Hi all.
Does anyone have access to a video that shows how to remove the rear sliding window sections from a T6.1 please?
I have a leak on both sides and have found a video that shows a logical cause and fix but I cannot for the life of me find a video showing me how to get the sliding window off...
I have these if anyone is interested, drivers and passenger side flush fit windows.
Tinted glass (15%) not film
They are used but were only in a van for a couple of months
£300 collected for the both.
Could any members on here who have had their T6 slider windows replaced under warranty [ or not ] because of leaking be so kind to let me know if they replace the entire side window [ fixed piece + slider window ] or just the slider window itself ? It will help in ascertaining whether VW were /...
I know that the leaky T6 side slider windows have been discussed many times but just wanted to make members aware that this can have serious consequences . My T6 2016 had a leaky passenger side rear slider from new . I took it back to the dealership who stated that the 'drain holes' get blocked...
Hello
I would really appreciate some advice as to how people have finished the inside of their window fitment after installing OEM sliding windows into a panel van door.
I am aware that I will have to cut an additional part of the frame to get the sliding window to fit correctly but I wan to...
Hi All, I've got a '17 plate T6 204 with Twin Sliders with flush fitting sliding windows.
Drivers side rear sliding window has been leaking since I purchased it from Listers in June.
Various delays with Listers (incl. lost paper work?!), has meant that it's only recently gone back in to get...
For those of you like me who've gone down the panel van route, what sliding window choice did you go for ? . I've heard horror stories about original vw ones regarding leaking, but a few people I know that own kombis have had no issues.
I'd prefer to go original but open to suggestions on...
I am selecting windows to fit to a swb panel T6 and really like the flush fit sliders from VGC. Can anyone advise how prone to leaks these particular windows are as I know the older OEM flush sliders were leaky.
If there is mention of VGC slider leaks my back up plan is indented sliders...
I took delivery of my windows last week but didn't realise the make I went for were only rear slider on the side window. I contacted the company and they agreed I could return them....... but now I'm wondering whats the benefits of a rear slider? I really like the shallow recess of the...
Hello all. I am after ordering 2 sliding windows prior to the arrival of my 6.1 in March. I see that VGC have them to pre order from March but I cant really justify paying £850 for 2 windows. I appreciate they are probably very good but has anyone found a cheaper alternative, otherwise I may...
Is it normal to have aftermarket flush fit sliding windows without a drain?
Unless I have totally missed the drain holes I'm a little confused as to where the water goes if any water should go into the runner in which the sliding part of the window travels along.
hopefully someone can put me right here
Looking to have the twin electric doors on T6 caravelle re-glazed
Currently have fixed glass but want opening windows, a couple places have given me quotes but say they only fit the window that sticks out and isn’t flush against the door like I already...
Gents
Just installed the plywood floor in my campervan conversion and hopefully dry fitting the RIB seat this weekend for Christmas transportation and i noticed this staining around the one wheelarch edge of the ply, its only on the drivers side and on touch does not feel wet? Is it just...
After reading various threads I understand that the OEM flush windows have had problems with leaking. I also understand that there now aftermarket ones available and have found a few via searches. My question is what are the best ones?
