fog lights
  1. Dripster
    Sold T6 LED Fog Light Kit With Auto Headlight Upgrade Kit, Travelin-Lite
    I bought this key about two years ago, just haven't got around to fitting it and figure at this rate I may as well clear the space. Listed now at £190 but out of stock, I paid £145 and would take £100 + £5 P&P, or pick up from Ilkley, West Yorks. T6 LED Fog Light Kit With Auto Headlight Upgrade Kit
  2. Finchy
    Sold T6 Front Fog lights inc loom
    Genuine VW T6 front fog lights including bulbs & wiring loom Collection from Marlow Bucks £150.00
  3. Jollyvan
    Sold T6 Lower Grille: End Trims in Gloss Black. £50
    T6 Lower Grill Trims for Vans with Fog lights and paring sensors. In Gloss Black Previously fitted to an other members van but I never got round to fitting. Postage included.
  4. M
    Which BCM for Fog lights/ corning
    I have a 2018 t6 trendline and looking at retro fitting OEM fog light setup. How do I find out if my BCM will accept it? VCDS? Which version is needed?
  5. M
    Parts needed
    Hi Guys. I know this has probably been asked multiple times but does any one have access to a parts diagram or can help with some part numbers as I can find what I’m looking for. I had a couple of things flagged on my mot on my 19 plate Sportline last week that I would like to get sorted: -...
  6. Peace Love and Stoke
    T6 Bumper removal to fit Foglights??
    Hey everyone, I had a quick look but I presume I need to remove the front bumper to fit new foglights?! I'm upgrading to yellow from standard. Thanks
  7. stupot
    Drivers side fog light - more wiring in the access hole… any ideas?
    Hi folks, went to change the drivers side fog light bulb and in the access hole were a couple of other chunky looking cables, quite big connector blocks (bit like the ones in the back of headlights). Looked like they were getting a bit wet and grubby so made me wonder what they are for, any...
  8. V
    Front foglamp inop [Resolved]
    2018 T6. I've lost the feed to the nearside front foglamp (factory fit). Is there a common wiring issue I need to check before getting in about it?
  9. P
    Wanted T6 lower fog light and grills
    List t5 front underth plastics needed Front lower fog lights and insurts wanted. Possibly nice set off 18/19 inch alloys black / bronze / gold
  10. F2JON
    Sold T6- t6.1 fog lights
    Free to a good home, anyone that wishes to collect I’m not posting them, they’re travelinlite fogs not genuine, I’ve replaced them with genuine as they kept misting up but I think it was down to the bulbs I had in . Hence I’m giving them away before I bin them . There’s three in total two...
  11. Texxaco
    Sold Gloss black fog light surrounds
    I have these from my old bumper for sale. Two gloss front bumper fog light surrounds. They are not the easiest to fit, front bumper off and loosen the bumper brackets left and right the clip the surrounds in place and reseat the brackets. The fog light for in easy enough. £40 plus postage.
  12. C
    T6.1 foglight coding in adaptations
    Hi all, I'm wiring foglights to a 2020 t6.1. I have fitted the lights and fitted the wires to pins, 3&40 on the bcm. I have gone into adaptations and I'm not sure what to do now. Any help would be greatly appreciated. I fitted a new switch with a front foglight position.
  13. Dwuk2000
    Rear fog light not working
    Hi, Van failed MOT today due to no rear fog light, was hoping it was an easy fix but doesn't seem so. It's an 2017 ex-AA van with Genuine LED rears fitted, I've checked the cabling and as some say the Grey/White cable should be in slot 2 and others 5, have tested both. Checked the 15amp fuse...
  14. J99kom87
    Aftermarket Fog light kit issue
    Morning all after a bit of advice regarding the aftermarket travel-in-lite fog light kit with auto headlight switch. So they’re installed and they work great my only issue is when the auto headlights come on it also turns on the front fogs. When I turn headlights on manually the fogs stay off...
  15. Dundee_Kev
    Front Fog Wiring Connectors
    Evening all, I have just fitted front fogs to my t6. They were from AliExpress and came with the universal wiring with relay attached. As I want them working as per factory, I have got rid of the relay, earthed to the body and run both live wires from the lights into drivers footwell and a...
  16. Texxaco
    Sold OEM front Fog lights
    Gauging interest as I have a set of genuine Front Fog lights with OEM associated wiring available. With the above comes a set of Autobeam LED bulbs link below Autobeam LED bulbs Looking for £100
  17. L
    T6 Turning / Fog Light Bulb which ones should I get? White LEDs?
    T6 Fog Light Bulb which ones should I get? White LEDs? I've seen prices from £17 to £40+ Assume as long as they are CanBus ok / Error Free thats all I need? CHEAP ONES £17...
  18. N
    Insert needed for Sportline splitter
    Looking for a piece that fits in here what's it called and where can i get one,drivers side
  19. fezza68
    Auto headlight switch help.
    Hi all. Is there anyone in the manchester area with auto headlights on their van and start stop who is willing to help me out?. Mine has developed a fault where the front fogs have stopped working on the switch. I wanna try another headlight switch to see if thats the problem before i buy one. Ta.
  20. carlg
    Sold Vw T6 gloss black fog light surrounds
    For sale brand new never fitted gloss black fog light surrounds with parking sensor holes £50 free post
