Hi all.
I've had my new to me 2019 T6 for a month. So far no issues exept today when driving in town, approaching traffic lights, a symbol appeared on the MFD along with a beep. A while later, the same symbol and beep but the brakes also jammed on momentarily. There were no cars or obstacles in...
Had a look on older threads but can’t find an answer
Van started playing up the other week
When selecting reverse long beep
(Park assist not working)
This also takes out all the parking sensors and the rear camera
Was happening Intermittently
Carista says front right sensor fault
Today took...
Front camera wiring diagram for driver assist systems, this is the camera for lane change assist etc
For front camera for HBA/main beam assist check here - T6.1 - Front Camera (HBA) Wiring Diagram
On my T6 I am greeted with "Front Assist unavailable" daily since I got the van. OBDEleven shows ACC sensor misadjusted. I can clear / reset and ACC works as expected but the fault comes back. I note that the little radar box in the front bumper is loose / moves at the bottom, pretty certain...
I've just had a towbar fitted with dedicated electrics to a T6.1 2021 model and I'm getting this error.
Auto electrician reckons it'll clear when it's driven but I find this very hard to believe.
Ian
I have rear park and camera and want to add fronts.
I know I have to replace my 4k PDC controller for an 8k one (5C5919475) and also need another bleeper (8E0919279) four sensors (5Q0919275B) plus brackets (7E5919493E/4E / 93D/94D)
Anyone know if this loom (Kufatec) will reach the replaced PDC...
On the last two longish drives we've done (135 miles down to Herefordshire and back for a camping trip) the dash has flashed up with an error -
Front Assist. No sensor view
This is usually around 100 miles in. It's also happened a couple other times before this.
Does anyone else...
My 67 plate has the front radar fitted (ugly thing!). Does this mean it has ACC or is it possible that the part is fitted but not necessarily wired in/activated? Is there a way of telling (apart from 'testing' it).
Cheers
ACC & City Braking - How Its Done -
what is it?
Adaptive cruise control (ACC)
Adaptive cruise control (ACC) is a speed control system with intelligent control of the vehicle speed.
The system accelerates and decelerates comfortably. Adaptive cruise control is a combination of a speed
and...
I've just taken delivery of a new T6 Kombi T32 204 DSG which is supposed to have ACC. It has the radar on the front but the steering wheel is like the attached image. We have two other T6's on our fleet which have the normal button that allows you to set the distance so I am thinking my vehicle...
Ok T6 Gods . . . . . . heres one for you.
So we have a T32 MY18 204ps with DSG. (PDC F&R if that helps)
The ACC, front assist & city breaking were all opted for....
Now the ACC seems to work a dream, following the car in-front up to the CC speed limit set and also slowing down to a stop if...
