front wipers
  1. M
    Thudding with front wiper drivers side
    Hi all. I have an annoying thudding noise on my t6 from my front wiper, on the drivers side. It seems to be when the wipers change direction to do back down towards the bottom of the windscreen. It's been there since I've had the van but only noticing it more recently as I've had my van back...
  2. T
    Windscreen wipers won’t turn off in off postion
    Im having a proper as to where my wipers intermittently have a mind of their own. Only some journeys when in the off position they wont knock off. When happening they go on every 18 seconds and this doesn’t change when altering the timer. Took it back to the second hand dealer and he’s basically...
  3. K
    Parking pilot and wiper errors- not related though as at different times!
    After a jet wash my rear parking pilot has stopped working other than a longish beep when I first put it into reverse. Any ideas how to fix? Also since I had the van repaired after I was driven into at the front the wipers don’t stay on the rain sensor intermittent. They only stay on slow for 4...
  4. P
    Wiper problem
    Bit of a issuise my wipers work , but arnt working on intermitant speed on the stork would anyone possibly possibly point me a daigram , could be a wire
  5. Tony Abbott
    window wiper problemo
    Hi, I have a front window wiper issue. As you can see from the pictures, both wipers are 2feet in length but when they are active, the dvrs side wiper goes off the window screen onto the vehicle body, any ideas?
  6. Texxaco
    Lack of front wipers
    Imagine, throw warm water on your frozen windscreen, get in the van, flick the wipers on and nowt! Try again… nothing. Trip to @Dav-Tec early morning, thankfully no wipers required on my journey. Phew!! Chris scans the van with VCDS, looks like a replacement stalk, ordered, fitted, still no...
  7. H
    Washer Wiper Woes [Resolved]
    Odd issue - front windscreen wipers don’t work from the stalk, but work fine on auto sensing. Windscreen wash doesn’t work for front and rear (replaced fuse and pump). Any ideas of anything else to check before booking it in? Many thanks
  8. Skyliner33
    Removing Wiper blade arm?
    Ok, I’m trying to remove the wiper arms on a T6.1. Now on the T6 I just removed the bolt and with a bit of force they pulled off. However I can’t seem to shift them on this van
  9. Sackmycook
    Intermittent wipers not working [RESOLVED]
    My intermittent wipers dont seem to be working? All other settings for the wipers work fine. My van is T6 Trendline 102 MY2019. Just had some minor electrical works carried out at the converters, spots and switches. Is it on a separate fuse that could have blown ? Or was I not driving fast...
  10. E
    T6 California Wipers and washer pump randomly come on
    Hello everyone, I was sitting on idle for about 15 minutes last week and suddenly the wipers did two sweeps of the screen. My Cali does have rain sensor but the stalk was set to the off poisition, I confirmed it by moving the stalk to the maximum setting and sure enough, the wipers went at...
  11. M
    T6/T6.1 operate front wipers with ignition off
    Hi there, Another feature I need to implement is operating the front wipers (even if it is just a single "wipe") with the ignition off. I can't seem to find any schematics on the site which have any detail about the front wiper system. (I found the rear wiper diagrams and got that all...
  12. Ann3x
    Wiper mechanism replacement
    So, 1stly, yes I'm an idiot who needs to buy a torque wrench.... Secondly I've just sheared off my front wiper bolt. Is it new mechanism time or can I swap just the one pivot / wiper mount?
  13. Nuttymike
    Front wipers on my t6
    Hi..anyone know where the fuse is for the front wipers?? It seems to be top secret
  14. Cham13
    Front Wipers Failing
    My wipers have more or less given up and I think its most likely the motor? If I spray water onto the front screen they don't wipe automatically, however if I switch them onto full power, after several seconds they start moving, but stick at times and then its a matter of stopping them at the...
  15. J88arv
    Heated Window Screen Help
    Hi all, I’ve searched and downloaded the fuse layout but to be honest quite confused as to which fuse it could be for my heated screen. Can anybody help as it’s not working at the moment or does it just take sometime to warm up?? I ask as we used to have a ford and the screen was instant thanks
  16. R
    Auto Wiper And Auto Headlights
    Hi all, I fitted a new rear view mirror in my T6 67 Highline - one with built in dash cam/ reverse cam etc. That's fine and working great, but... I was under the impression that auto headlights had a sensor built into the oem mirror and that auto wipers sensor was on the mirror mounting...
  17. M
    Wipers not working
    Pick up 68 plate t6 transporter panel van Saturday ,had reverse camara fitted and tow bar,never checked everything now my front wipers are not working ,any advise would be gratefully accepted
  18. Littleblackflash
    Auto Wipers - Retrofit?
    I've had my T6 almost 2 months now and I've just noticed I don't have auto rain sensing wipers. My van (soon to be camper) is a 65plate Highline and came with Auto headlights, but from what I can work out, not the auto wiper. How difficult is it to add the rain sensor? My van has a sensor on...
