My fuel gauge is showing full and I suspect the float/sender is stuck. Can I access the sender from inside the van through an inspection hole or do I have to drop the tank? Thanks.
Hi all I wonder if anyone can help, my T6 had a flat battery today and wouldn’t turn over, I put it on a trickle charge fo a bit and got it started but now my fuel gauge is not showing any increments the fuel light is on and it’s reading 0 miles in tank ? Has anyone ever experienced this before...
I dropped the fuel tank to fit a diesel heater and am now showing as no fuel on the gauge. there is fuel in there though. Took everything back out and made sure there were no obstructions and the sender float was working correctly. I downloaded the fuse locations to check fuses but what I...
I have just returned from a trip to Spain. Last month i went to Austria twice.
When I fill up to the max the Fuel gauge does not appear to move from Full for between 60-100 miles:especially on the motorway. Then slowly starts to work as planned. The range of the van sometimes changes as I...
Ok so thread title may be a little optimistic but it made you look any way!
Just wondering if anyone else’s van does this or indeed I have a problem
Every time I get down to a quarter of a tank around 100 mile range on dash when I start van again needle goes up slightly and range gets bigger...
Just introducing myself to the forum. I have purchased a T6 (2016) newly converted by a professional converter near Solihull. I already have my first problem in that the fuel gauge is not working properly after the diesel heater was installed. I am not a mechanic but after scouting around on the...
Twice now we have filled our T6.1 up and both times left it until the diesel pump clicked off. When I jumped in I expected to see the gauge reading full, but it's always showing one black line off of the top one.
Is this normal or is there something I need to have looked at?
Do you think the...
Hi everyone, hope you can help please. I have a 2016 t6 caravelle and filled her up with diesel this evening along with 8 litres of ad blue as the dash was telling me to fill up a max of 9.5ltr of ad blue. Put the diesel in where the diesel is to go and also the ad blue where the ad blue is to...
So over the weekend I dropped the tank to fit a dip tube/standpipe for my diesel heater. Put it all in no issues, bolted the tank back up.
Started up the van several times and noticed that i had 100 extra miles of range.
Thought my dip tube must be fouling the float arm so pulled it back to...
Had T6 a week (66 plate)
I have removed front seats and fitted pop top roof and now fuel gauge has stopped registering
startline clocks if that makes any difference
thanks in advance
Hi there I bought a brand new pre reg T6 a few weeks ago to convert.
I've had the dash out to run the B2B and had the passenger seat base out, altered the wires and fitted a swivel base.
the problem I’m now having is the fuel gage isn’t working!
I've removed the base and checked for trapped...
hello,
I have a 2015 T6 T28 180BHP DSG..
I have a few issues that need sorting on it, the first is that the fuel gauge doesn’t work. I’ve had the tank off and checked the sender unit (it looked fine) I’ve also tried another sender unit and still didn’t work? Checked the wiring from the tank to...
When I first got my van I had an issue with the fuel gauge sticking on full - at the time I had been driving on some very steep roads in the Lake District and figured that it was down to the tank float (or whatever is in there) somehow getting stuck at the top of the tank when the van was at an...
