fuel pump
  1. T
    2006 T5 2.5 AXD Engine Not Starting California Camper conversion.
    This is my very first post, so please be gentle. My brother in Law (Ron) has the above vehicle which will not start. The following is an trail of what has happened since the vehicle decided not to start back in Dec 2023. Ron having a funeral to attend later in the day, started the vehicle to...
  2. T
    For Sale VW T6 TSI Fuel pump
    For sale a genuine factory fuel pump from my 2018 TSI The pump traveled around 14k miles. Can post, alternatively collection Chippenham or Aylesbury I also have numerous other parts for sale Fuel pump Exhausts Bumper plastics Air intake Bose hoses Any questions please ask
  3. P
    Ticking Fuel Pump
    Hi all. Got a problem that needs a bit of logical thing and deduction. I have a ticking noise from my fuel pump even when I’ve stopped the engine, got out, and locked the vehicle. I remove the fuel pump relay fuse and it stops. Put the fuse back in and no ticking. Start and stop the engine and...
  4. K
    Non-Starter: air out rail and injectors next?
    hi, i have replaced my glow plugs, and took out the fuel-rail, assambled all and got all air out of the system. but engine does not start. do i have to take to injectors out and get them filled with diesel to get rid of the air inside the injectors? also when ignition on i measure 2.5Vdc on the...
  5. T
    Can you hear fuel pump prime?
    Does the in tank fuel pump prime when the van unlocked or door opened? Should I be able to hear it?
  6. mmi
    [T6_measured] 01-Engine - Built-in test for Transfer fuel pump
    A quick DIY way to test fuel lift pump's basic functionality. The test takes advantage of engine's fuel high pressure sensor (in fuel rail). Running the lift pump continuosly makes the pressure eventually "leak" through high pressure pump and can be detected by fuel pressure sensor. As a side...
  7. W
    Van engine not starting correctly when I take my foot off the brake.
    Here’s an odd one folks. Four occasions now I have almost stopped and the engine cuts out (start stop), once prematurely, the rest as normal. On trying to restart, it just judders constantly. I’ve been in awkward positions when it happened and after a minute or so, switch it all off, then...
  8. K
    When do fuel pumps activate
    Hi do the fuel pumps prime when ignition turned on I’m sure when I got the van I could here it pumping when ignition was on but here nothing now when van first fires in the morning get a slight judder not every time if you give it a bit of gas it goes straight away ran it though vcds both pumps...
  9. Del94
    Intermittent Start Up Fault - Resolved!
    So, I’m just on my way back to the service centre to collect my van again! https://www.t6forum.com/threads/start-up-fault.33384/ After the centre replaced the crank sensor ( third visit, first visit fuel pressure sensor - second timing belt and tensioner ) the problem worsened dramatically...
  10. peteslack
    Advice on fuel pump setup
    Changing my cam belt following the forums instructions carefully as its the first one I've done. 2.0lt 150bhp. 2017 Have the timing covers removed and checking the setting pins (with the old belt still on) notice that the fuel pump is off what the vw service manual specified. Looking about a...
  11. Steved55
    Need to bleed after removing fuel tank?
    Have just re installed fuel tank after being off van for about 4 weeks (t6 150dsg) and flattened the battery trying to start it! Recharged the battery and after about 30 seconds cranking she fired up and seemed to run perfectly on the drive. Next day exactly the same, took about 30 seconds...
  12. Y
    Hissing Noise Region of Fuel Tank
    Have just taken delivery of my T32 Kombi LWB 199, which is generally great, however there is a hissing noise from the region of the fuel tank. It starts on starting the engine and is audible from inside, loudest around the bench seat. Stepping outside it is much louder and appears to be coming...
  13. G
    Night Heater help - Loud buzzing noise from Fuel Sender/Diesel Tank
    Hi all, I'm having some trouble with my underslung diesel heater installation on my T6 and any advice would be greatly appreciated. I've placed the diesel pick up line in the sender unit (not 100% sure where the "loose" end needed to go), I've attached an image looking from above. Van starts...
  14. Pauly
    T6 & T6.1 Diesel Fuel Supply System Workshop Manual 2019
    Workshop manual covering fuel supply system for all diesel engined vehicles This document covers removal/installation of system components like tank/pump/filters etc and also covers misfuelling procedures VIP Membership is required to download this document
  15. Depron Donkey
    Fuel Tank Draining
    I have to drain all the fuel from an almost full tank. Anyone know where the relays are to power the pumps so I can disconnect the fuel line in the engine bay and get it to pump its own fuel out? Or, anyone know an easier way?
  16. Lady T
    Fuel Tank / Pump Hissing (Washing-Machine) Noise
    Hi I have just picked up my brand new T32 204ps 4motion and it has driven like a dream for 10 days the engine has been purring so beautifully quiet. I filled the tank up with fuel on the 10th day and drove off with a terrible hissing sound coming from the fuel pump just below the fuel caps and...
  17. K
    204 dsg hissing noise from underneath
    as above really, my t30 204 dsg panel van unnoticed this morning has a hissing noise at idle from underneath, almost sounds like gas is escaping from the exhaust. Anyone else got similar?
