fuse box
  1. Fordrich
    Interactive FUSE LAYOUT for VW Caravelle T 6 2016
    I was looking for a fuse diagram for my VW Caravelle T6.1 on a 2016 plate and I came across this awesome interactive diagram. Just thought I would share it with you if you haven't seen it before. You can roll over each fuse and it will tell you what it is... or you can click on the description...
  2. 360ian
    Second 12v Fuse Board
    Hi all, Im thinking of adding an additional 12v fuse board at the back of my van to power spotlights etc. I already have one located under the drivers seat but was wondering what the best way of wiring the second board would be? Do I just add in a second + and - cable from the first 12v fuse...
  3. Phil_j89
    For Sale VW Additional Fusebox 000 055 212A
    VW Additional Fusebox 000 055 212A for towbar, but could be used as an extra fuse box if fitting more 12v components. 12V ignition live under the seats perhaps? Was bought to fit a tow bar, but already had the wiring required from factory. Looking for £35 posted
  4. Droneshadow
    H7 DRL issue
    I mentioned this in another post but I’m tearing my hair out with it now, so I’ll ask directly in case anyone can shed any more light on it. (Pardon the pun) 2019 T6 Changed the headlights to the factory H7 ones, and fitted Twenty20 DRLs All worked fine fine for a couple of weeks, then bulb...
  5. C
    T6.1 Blackvue Dashcam Install
    Hi all, I have the BlackVue DR750X-2CH Plus which I want to hardwire into my 2022 T6.1 transporter. I need to find a suitable permanent supply and a switched supply in the fuse box. I will earth it somewhere on the body. VW don’t supply a diagram so I am struggling. Here is a pic of my fuse...
  6. ginkster
    [T6] 12V Dash Sockets both not working
    Both of my 12V sockets on the dash (top one and the centre one by gear stick) have stopped working for some reason. I’ve checked the fuses in the central fuse box under the gear lever and these are ok. I changed the 20A one (SF11) for an LED fuse but this does not light and have checked the 15A...
  7. DubHaus
    T6.1 Fusebox SC access?
    Hi all, I’ve had a quick search and can’t find how to gain access to the rear of the main fuse box in a T6.1 (main fuse box under light switch) can anyone help /give advice / how to? I’m needing to redo some previously retrofitted wiring and also adding in Side Assist and TPMS fuse positions...
  8. C
    T6.1 2023 fuse box locations
    I have a 2023 T6.1 transporter, the sliding door and tailgate will open from the outside but no from the inside. It is although the deadlocks are stuck. I am trying to locate all the fuse boxes but can only find the one on the right had side of the steering wheel, does anyone know where the...
  9. roadtripper
    FREE Fuse box connector 5Q0 972 752
    Having stripped a salvage VW Golf MK7 fuse box for some relays and connectors I have a high current fuse box connector 5Q0 972 752 spare with decent tails. I don't think it's used on the Transporter but on the off chance someone has other VWs and it would be useful I can stick it in the post...
  10. H
    T6.1 Fusebox cover removal tips
    How hard do I pull the fuse box cover to remove it on a T6.1? My van looks like the one at 55s of this video but he seems to just lightly pull on the cover, straight away from the rest of the fascia, whereas I've tried a reasonable amount of force with no luck. I didn't want to overdo it just...
  11. D
    Fuse Board Gubbins
    2 slots above the centre run two red 10amp fuses is the slot where my dc-dc piggy back is normally located. On the left of the slot you can see a silver metal thingymabob. This is not present in any other open slots. Am I right in thinking this is the pin that gets inserted into a rear of a...
  12. M
    Lower dash removal to retrieve fuses
    i need help, I've dropped 3 of the square fuses trying to get one in for the upper dash 12v socket. I've got the glove and the two foot well panels box out. and removed all the screws i can find but still cant get the trim away round the fuse box, is it one piece round the gear stick as well...
  13. ERICTHEVAN
    Sold Unused Electrics Kit incl Fuse Box, Contol Panel, 240V charger CBE PC210 Kit (less consumer unit)
    CBE PC210 Kit (less consumer unit) I purchased this kit from Kiravans back in March but, with the exception of the consumer unit which I have put in the van, I have not used/installed any of it. The pack is made up of the following: CBE DS300-UK - Fused Distribution Box CBE PC210-ST -...
  14. Texxaco
    Lack of front wipers
    Imagine, throw warm water on your frozen windscreen, get in the van, flick the wipers on and nowt! Try again… nothing. Trip to @Dav-Tec early morning, thankfully no wipers required on my journey. Phew!! Chris scans the van with VCDS, looks like a replacement stalk, ordered, fitted, still no...
  15. alexfh
    FUSEBOX!!!
    Hi im Trying to locate my fuse box on my T6 transporter but its supposed to be under send to the left of the glovebox but i cant see how to detach it ,........HELP
  16. B
    Driver side fuse box removal.
    Looking for some help. I've fitted a towbar and PF jones dedicated electrics kit to my 2021 T6.1 but can't complete the CANBus connections without removing the driver side fuse box to access the rear connectors. I've got the panels off but can't see how the fuse box is secured. Can anyone point...
  17. M
    T6.1 Interior light fuse
    Hi all, Apologies if this has been discussed before, spent all morning searching and can’t find the answer. T6.1 rear interior light fuse.. I’ve become VIP, I’ve downloaded the diagrams from the Downloads section, still can’t seem to work out which one it is.. I’ve attached a photo of my...
  18. Z
    What is this fuse?
    What is this fuse? Thanks
  19. R
    T6.1 switched live pick up (CTEK 250SE) from internal fuse panel, drivers side
    Hi, Having trawled the forum, and probably looking for a simplistic reply, I am struggling to see whether anyone has answered the following question. What is the equivalent fuse position to that quoted for the prior fuse panel in the central position - "5th fuse down on the right hand side"...
  20. Molldog
    T6.1 USB-C Port not working
    New van day yesterday. On the drive home I had cause to plug in my phone for a charge up on my T6.1. I bought a couple of adaptors to allow me to plug a straight forward USB plug into the USB-C socket. Disappointed to find that only one of them appeared to be working! Could this be a fuse...
