**UPDATE* I now have the instructions, kindly supplied by Paynewright and are visible below.
Has anyone got the instructions for fitting the tow bar electrics fuse panel, 000055212A, that fits under the passenger seat. I have the genuine kit but it didn't come with instructions.
Specifically...
I'm looking to run a cable from the main battery into the cabin. Anyone know if there is an easy route through, maybe using an existing path, or do I have to think about drilling a new hole in the engine bay bulkhead (gulp). Any advice much appreciated.
Hi all, I need to add another +12v feed from the starter battery terminal , what's the best way as there isn't much room available underneath the nut on the terminal. Any suggestions please? It's a 2021 t6.1. Thanks in advance
I'm going to try making my DCDC leisure battery install a bit neater, and as part of this was going to move the fuse that is between the van battery and DCDC charger down in to the E-box (underneath the van battery) like the factory fitted aux battery install (ours didn't come with this option)...
Fuse Chart/Listing For Fuse Holder SA - In Engine Compartment
Located under battery, this fusebox contains the primary heavy duty feeds from the battery to main vehicle equipment
Below is a sample image of part of the document
Fuse Chart/Listing For Fuse Holder SA - Engine Compartment
Located in 'E-Box' underneath battery, this fusebox contains the primary heavy duty feeds from the battery to main vehicle equipment
