fuse box sb
  1. Deaks
    [Merge] IGN/Switched live in engine bay
    So I just fitted some swanky new spots on to the A bar and they look great.The spots have these nice DRL strips in each side and my plan was to tap into the DRL feed from the R/H headlight connector, This tap worked great for main beam and for the Sport DRL into dipped beam, but the Headlight...
  2. MartyMoose
    Engine bay cable route through bulkhead/firewall to cabin
    I'm looking to run a cable from the main battery into the cabin. Anyone know if there is an easy route through, maybe using an existing path, or do I have to think about drilling a new hole in the engine bay bulkhead (gulp). Any advice much appreciated.
  3. Pedro20001
    T6.1 under bonnet electrics
    Hi all, I need to add another +12v feed from the starter battery terminal , what's the best way as there isn't much room available underneath the nut on the terminal. Any suggestions please? It's a 2021 t6.1. Thanks in advance
  4. Pauly
    T6.1 VW T6.1 Fusebox/Fuse Chart SB - Engine Bay 05/2019
    Fuse Chart/Listing For Fuse Holder SB - In Engine Compartment Located in front of battery, this fusebox powers the majority of the engine circuits VIP Membership is required to download this document Below is a sample image of part of the document
  5. Loz
    T6 Fuse Box layout map Box B 2018-01-19
