fuse box sc
  1. Deaks
    [Merge] IGN/Switched live in engine bay
    So I just fitted some swanky new spots on to the A bar and they look great.The spots have these nice DRL strips in each side and my plan was to tap into the DRL feed from the R/H headlight connector, This tap worked great for main beam and for the Sport DRL into dipped beam, but the Headlight...
  2. DubHaus
    T6.1 Fusebox SC access?
    Hi all, I’ve had a quick search and can’t find how to gain access to the rear of the main fuse box in a T6.1 (main fuse box under light switch) can anyone help /give advice / how to? I’m needing to redo some previously retrofitted wiring and also adding in Side Assist and TPMS fuse positions...
  3. C
    T6.1 2023 fuse box locations
    I have a 2023 T6.1 transporter, the sliding door and tailgate will open from the outside but no from the inside. It is although the deadlocks are stuck. I am trying to locate all the fuse boxes but can only find the one on the right had side of the steering wheel, does anyone know where the...
  4. Pauly
    T6.1 VW T6.1 Fusebox/Fuse Chart SC - Dashboard 05/2019
    Fuse Chart/Listing For Fuse Holder SC - Drivers Side Dashboard Located inside the dash by steering wheel/light switch, this fusebox powers the majority of the interior and convenience circuits VIP Membership is required to download this document Below is a sample image of part of the document
