fuse box sj
  1. Pedro20001
    T6.1 under bonnet electrics
    Hi all, I need to add another +12v feed from the starter battery terminal , what's the best way as there isn't much room available underneath the nut on the terminal. Any suggestions please? It's a 2021 t6.1. Thanks in advance
  2. Skyliner33
    T6.1 battery removal / access Fuse Box SJ
    I am in the process if planning a leisure battery install and dc-dc charger. However firstly I cant work out how to remove the battery to get access to the bulkhead grommets. Secondly is it possible to take power from the fusebox that is on top of the battery. I seem to have some of these unused.
  3. Pauly
    T6.1 VW T6.1 Fusebox/Fuse Chart SJ - Engine Bay 05/2019
    Fuse Chart/Listing For Fuse Holder SJ - In Engine Compartment Located by battery, this fusebox contains heavy duty main circuits VIP Membership is required to download this document Below is a sample image of part of the document
