fuse under passenger seat
  1. C
    T6.1 pax seat factory-LB wiring
    Hi, I'm new to the forum and have a question regarding my 2022 T6.1 Kombi. Under the single N/S passenger seat of a RHD Kombi is a long slim fuse box. This is fed by a fairly thick red wire which is permanently live and terminates and splits into a slightly thinner one and three thin ones which...
  2. S
    Is the rear lights loom under the front passenger seat
    Is the rear lights loom under the front passenger seat on 2017 T6
  3. campz
    T6.1 12v feed underneath seat?
    Hi, New to the VW world! I’ve seen some posts about a factory fitted perm live being available under the drivers seat in some 6.1 vans. We have just purchased a 6.1 shuttle and will be fitting a split charge, is this true or will we need to run a new cable from the engine battery? thanks!
  4. Lukavell
    +/- Which is which???
    The two blue fuses are for the rear 12v sockets. I'm attaching them to the leisure battery but which of the red cables is + and which is -? The rear two are a thicker guage than the front two, one of which has yellow dashes on it. Any help greatly appreciated.
  5. Paynewright
    Passenger Seat - Trim And Wiring Plugs
    Swapping the front passenger seat over from twin to single I didn’t take any pics of the wiring plugs before I pulled them out of their holder as I thought they’d just sit on the floor under the new single seat. Then I spotted the wiring plug cage on the new seat - doh!! I’ve got them all in OK...
  6. R
    Permanent Live For 12v Usb Charger In Rear
    Hi, I’m looking to install some 12v USB chargers in the rear for when we’re travelling. Wanted to know if there is a permanent live under the passenger seat in the blocks that I can piggy back rather than pulling the dash about. Also, I’m not running a leisure battery so wondered what effect...
  7. Jason Stancliffe
    12v Socket Not Working
    Hi My 12v socket has stopped working on top of dash . I’m thinking probably a fuse has gone. Anyone know which fuse and size it might be to check? Thanks
  8. Deaky
    Fuse Box SH
    this is the little fuse box under my passenger seat. I want to re locate these fuses into a new larger fuse box under the seat where my other leisure electrics will be held. I’d like to label them so it would be handy to know what they are. For reference I have a factory fitted aux battery...
  9. T
    Ignition Live under Passenger Seat
    I have a factory fit leisure battery under the passenger seat. Is there a simple ignition live under there somewhere as well as the bcm output to control the main split charge relay?
  10. R
    Wiring Under Passenger Bench Seat
    Hi I would like to permanently remove the passenger bench seat and not put anything in to replace it so as the only seat in the front is the drivers. The only thing that is giving me pause is the wiring connections in the seat center frame, will removing the seat trigger error faults or as long...
  11. Glenn Board
    Where would I find the fuse for this?
    hi, can anyone please tell me the fuse associated with this relay, I’ve blown it so need to replace? Thanks in advance Ps it’s under the passenger seat
