gearbox oil
  1. Epic-Rob
    Gearbox oil - grade?
    Just in the process of changing dual mass flywheel in a 2017 manual 6sp 4mo, (bi turbo engine) so i have inquired to VW here in NZ for transition fluid they are telling me 110quid a LITER and i need 3l thats a bit eye watering so i thought i should go elsewhere. Can anyone tell me the actual...
  2. T
    T5.1 transmission oil change
    Hello I'm new to the forum and just bought a 2015 t5.1 4 motion which I'll going to doing all the service items now, as I'm not completely sure when they where last done. On my list is to do the transmission oil change. i found the info below about the oil type and capacity. there are also a few...
  3. VesselPal
    Haldex oil missing
    Just did the first haldex service on my T6. After comparing the volumes of the new and old fluid I noticed that 1dl was missing. Did that in anyway damage the clutch / pump? Its done about 60.000km.
  4. VesselPal
    Haldex Fill plug referance
    Excuse my ignorance, where would somebody go to took for a specific part number? Looking for front and back diff fill&drain plugs to order from VW. Same goes for the gearbox. It's a T6 2018 4motion 110kW 6 speed manual.
  5. Gt Haywire
    T6 5th gear selection issue
    I wonder if someone could help me please. My T6 van 36000 miles 5 speed 2016 T30 Trendline van has a 5th gear shift issue. (Van in profile photo) I have just found it difficult to get into 5th gear. It's not hard to get it in, it just needs a slight push to get it there when driving! I have...
  6. R
    Gearbox Oil Change Procedure - 2016 150PS 6 Speed
    Hello All, Does anyone have the 2016 150PS Manual 6 Speed Gearbox Oil Change Procedure? Along with the correct oil type etc... Plenty of info on the DSG but need the manual box.
  7. D
    2016 T6 Bevel Box And Final Drive
    Hi All, I have a 2016 T6 Transporter with 4motion, just serviced the engine and transmission and was going to service the haldex, final drive and bevel box. to my surprise I could not find drain bungs for the diff or bevel box just ports to check levels. been told that these are fill for life...
  8. Alanmh
    How To Check Gearbox Oil?
    I am probably paranoid, and I am used to driving cars with the windows up and lots of sound deadening. But, I am noticing a whine noise on overrun from the gearbox, especially in second gear. With a big trip to France coming up, how do I check the gearbox oil level. As I say, its probably just...
