glove box
  1. M
    Glove Box can be locked or unlocked with anything that fits in the slot.
    Hi. I've got a Transporter 6.1 campervan conversion and I'm confused about the glove box locking. It has a slot into which I can insert the ignition key to lock it, but it seems that anything at all - screwdriver, lollystick, etc., - can be used to lock or unlock it. Is this a fault or a...
  2. CamperCaz
    Strange Connections inside Glove Box
    Hello Friends, I have a T5 Leisuredrive (just recently got it) I know nothing ha! Inside the glove box I see two leads with some sort of connections like a usb, see photo, what can they be? Also, there is a small black box with a stick-on aerial on the inside front windscreen, which may or...
  3. Mischa_b
    Part number of clips for upper glovebox?
    Hi, I want to replace my upper glove box with the Van-X model. When removing the existing glove box, two metal clips were broken (see photos). I searched Google completely inside out but couldn't find the correct part number. Can anyone help me here? Thank you in advance!
  4. P
    Convert the T6.1 Van-X magnetic glove box lid to hinged?
    Has anyone attempted to convert the T6.1 Van-X magnetic glove box lid to hinged?
  5. VanDamMan
    Sold OEM VW Glove Box/stowage trim
    For Sale Used….very good condition. £45 Collect or will take to Busfest 23
  6. dandan88
    Can this plastic tray part be replaced easily as one?
    Does anyone know if this tray boy with the texture can be replaced, the wife spilt nail glue on it ‍♂️ Cheers guys
  7. saxoboy
    For Sale LED Glove Box Light Kit
    Hi Guys, After a good few months of trying to get parts closer to the prices I know you guys will pay for them, I have got the Glove Box Light Kits back available. They are very easy to fit. It takes 20 mins to fit if you've taken your van apart before!....I will send full Janet and John...
  8. D
    Glove box wiring loom t6
    Hi all, I have just bought a glove box wiring loom off of ebay. Advertised as a aT6 glove box wiring loom, albeit also said originally from a Passat. I have the switch and the light, and have just ordered the 2 correct connectors for the switch and light as this loom does not have them. The...
  9. archersam
    6.1 Van-x Glove box insert - how I did it
    No instructions so guessed how to do it - Prise out the stereo surround - Remove the air vent The self adhesive pads were useless, the magnetic is super strong so it will pull the screws off your screwdriver tip EVEN if you have just magnetised the tip so youll need to have good dexterity...
  10. JiMsHaDY69
    Sold Genuine VW T6 Upper Glove Box Compartment
    Due to not researching if this fits a standard dash (it doesn't without modification to the dash) I have a brand new Genuine VW T6 Upper Glove Box Compartment in a gloss black for sale. Ideal replacement if you already have the comfort dash or if you are braver than me and fancy hacking up your...
  11. timthetinyhorse
    Best place to buy upper glovebox?
    Im looking to start upgrading my dash so looking for an upper glovebox unit, i have seen then on a few websites but the prices seem bonkers for what in effect is a plastic box.......think its because they are all painted etc. Im going to be painting all my interior vent surrounds etc so not...
  12. JonriceT6
    [Resolved] Annoying rattle behind glovebox.
    About a month ago, I had my rear speakers connected to my headunit. 2-3 weeks ago the vehicle developed one hell of an annoying rattle coming from inside the dash behind the glove box area. Only happens when driving in low revs or pulling off. Sounds like plastic rattling on the crappy...
  13. Hobbo
    Removal of dash USB/Aux-in socket
    Hope someone can help with this- I was having problems with the USB socket connected to my Pioneer head unit. The female USB was loose, when I took the plastic plate off the USB cable came out completely and is stuck somewhere in the dash. I can just about see it, but no end of fishing...
  14. Steved55
    Glove box connectors
    Hi all, I've managed to source a glove box with the light and switch already fitted, but no electrical plugs. Does anyone know part numbers please or where I can buy them without the light and switch? Many thanks Steve
  15. R
    Sold Comfort glovebox & regular dash surround and upper glovebox
    Managed to find a used comfort dash so up for sale is my old regular one. The glovebox is the comfort version and Is flocked, used but decent condition. Small tray has melted a bit where I had to heat it up to remove the 12v socket. Not sure if you’ll be able to reuse it but I’m sure they...
  16. Samro
    Pathetic T6.1 Glovebox
    I am delighted with my new T6.1 Highline van and all of the mods which have been completed......I am 99.9% happy.....but.... not only is the glove box only big enough for, erm, gloves, but it is nasty thin tacky plastic and frankly out of sync with the rest of my shiny new machine. Just the...
  17. A
    Glovebox door rattle
    Hi folks, my glovebox door rattles when it’s closed, when I press/hold it, the rattle stops… any ideas or fixes? I’ve tried a search but nothing is coming up. Just been on a trip around the highlands and it’s annoying the hell out of me.
  18. Lewislovesbread
    Sold 16” steel with tyre x4
    Hi Guys, 4x steel wheels 16" standard issue. all with good tread. Open to offers. Collection only please. cheers, lewis
  19. M
    T6.1 Glovebox Removal
    I’m trying to remove the glovebox from my T6.1 Kombi Startline for a leisure battery charge cable. I can remove the passenger dash side panel (with the airbag switch) and three screws below the glovebox, but now I’m stuck. I can’t see any other screws and nothing else is obviously budging when...
  20. JTT6
    Found Passenger dash air vent
    I have just installed a VanX glove box and managed to snap a clip on the dash vent in the process. Has anyone swapped their vents for the vanx ones or similar and have the originals no longer needed. Happy to pay a fair price.. Mine still fits but its really loose now and bugging me...
