h15 bulb
  1. T
    Replacement front light bulbs.
    I have a T6.1 (2020). I want to replace both the dipped beam (the set up is that the bulb is to the left as you look from the front) and the main beam, which is also the daytime running light (the bulb to the right as you look from the front). I want to get the brightest road legal bulbs I can...
  2. Pedro20001
    T6.1 H15 LED bulbs not working
    Hi all, I've just purchased a set from xenonsonline as recommended and when I installed the rhs bulb it throws an error code and doesn't light up. Has anyone come across this? I cleared codes with carista but they return. I have only installed 1 bulb not both but didn't presume this would affect...
  3. bluezie
    T6.1 H7 & H15 Bulb Upgrades
    Has anyone upgraded to the Osram Nightbreaker +200% H7's, and the Osram Cool Blue Intense H15's? How do the colour temperatures compare, do the look ok? I was hoping there would be some +200% Nightbreakers in H15, but it would appear the Osram cool blue is the only upgrade available.......
  4. F2JON
    How should t6.1 headlights work?
    Ok this may be a daft question but how to the standard t6.1 headlights work, Tonight I’ve changed my bulbs h7 and h15 drl bulb, I’ve just been out for a drive but when I put my high beam on it kills the main beam?? It just leaves the drl on , I've also noticed that the drl stay on with the main...
  5. S
    T6.1 Headlight types
    I have a 2020 shuttle and have asked the dealer I bought it from, and one other but they cannot tell me, I have tried euro car parts online and it comes up with, "sorry no bulbs found"it was the same with fuse positions why can't VW give an accurate print out of a vehicles spec, I hope to travel...
  6. T
    H15 DRL Help
    Hi all, So i've just purchased some H15 LED DRL's for my T6.1. Straight away when installing them, I noticed the orientation of the bulbs are wrong. Basically, the old halogen bulbs point vertically (up and down) whereas the new LED H15's when installed, point horizontal, which means there's no...
  7. A
    H15 bulb change
    Dip easy ok... main bean h7 how does it come out... manual says twist - will not move.... Anyone done this?
