halo ceiling
  1. Phil Blackburn
    Sold Halo Roof
    Plyworx Halo roof for SWB Twin slider, light grey suede centre with mid grey carpet halo. Full new fixing kit supplied. Comes complete with black LED colour change tape and colour wheel controller. Collection Manchester or maybe meet up. £350.
  2. tommy_t6.1
    Sold Ply worx Halo roof swb
    Plyworxs swb single slider halo roof for sale. Bought and fitted in Feb last year, so just coming up to 12 months old. Pop to is getting fitted soon so no longer needed. It's carpeted in faux alcantara/suede and smoke grey carpet. It has 6 black downlights fitted to the center section which I...
  3. saxoboy
    Sold HALO Roof - Carpeted with 8x Ceiling Lights & Strip LEDs - £350
    For Sale: HALO Roof - Carpeted with 8x Ceiling Lights & Strip LEDs. Carpeted in Black stretch carpet. The plywood template was from Plyworx a couple of years ago. I have just added a Skyline Skylow roof to my van and now have no need for this lovely HALO roof. It comes complete with a new...
  4. 8balladdict
    COB Lighting for Halo Roof
    Hi all. Anyone have any ideas of the best COB lighting strips to use for a halo roof ambient lighting install? Want a full 270 degree continuos surround so probably 6ish meters and ideally strips that can bend 90 degrees on the corners when horizontal rather than ones that need to be...
  5. p6raf
    "How to" fibre optic star look roof lining
    My son has severe cerabral palsy and as the van is primarily for his use. I wanted to make travelling a sensory experience for him. I remember seeing a rolls Royce on Top Gear that used fibre optics and decided that's what I wanted for him. After watching various YouTube videos I decided to...
  6. RossBamsey
    Halo Roof - LED Strip
    Hi Guys Just purchased (and received) a halo roof system from Plyworx. I didn't purchase the LED lighting strip from them, so was wondering if there was a specific product people recommend i use ? Cheers Ross
  7. RossBamsey
    Halo Ceiling - dimensions required
    Hi Guys Trying to find the dimensions of the halo roof so I know how much lining material is required - does anyone know where i can find these ? Looked online with 0 results The suede flex on Harrison Trim supplies comes as 1.5m wide so wondering if i ordered 3m of that would it be enough to...
  8. F
    Halo lighting help - four wires instead of two
    I have installed a halo roof in my van and I’m in the process of trying to wire in the halo lights I ordered. Problem is they came with a dimmer switch fitted which I didn’t want as I have fitted a dimmer switch into the van ready for them. I assumed I could just cut this off (worked with other...
  9. A
    Sold PlyWorks Halo Roof Panel Carpeted
    Hello all, I’m about to get a poptop conversion and as a result no longer require my installed PlyWorx halo roof, its be in the van for about 18 months and still in great condition. It comes with the main roof covered in purple easysuede liner and the halo ring covered easyliner carpet in...
  10. B
    Interior light switching - positive or negative?
    Hi I have recently installed a halo roof into my T6 van I added some additional spotlights that run directly to my leisure battery, I have put two extra spots in the centre of the van for when the passengers go in to the van. I am trying to get it to run on the original VW electrics however I...
  11. Butcher8109
    Found Halo Roof
    As above - looking for a halo roof. Finished / unfinished / new / used … open to what’s out there Cheers
  12. Savgav1
    Plyworx Halo LED lighting kit
    Has anyone used the yworx led halo lighting kit? Are they any good and worth the money
  13. R
    Halo roof/ leisure battery
    Looking at getting halo roof fitted, and been told will need a leisure battery fitted first? Is this true? Thanks
  14. Mike Dean
    Poptop Mood Lighting Options.
    I’m having a PopTop cut in over the next few weeks. At the moment I have down-lights throughout the rear, obviously these will have to be either relocated to the sides, or replaced with LED strip lights. I like the idea of LED strips either side and not have individual down-lights. I had a...
  15. R
    Halo Roof lighting
    Im after a halo roof for my t6 lwb, been looking at this one from eBay, just wondering what lights would be needed to fit in the slots, and also how would they be wired up to existing wires from the old headliner. Thanks
  16. B
    Halo + LED interior lights
    Hi, I am fitting a halo roof in the rear and looking to wire the LED lights on a 3 way switch - to come on when doors are open, off and on. I don't currently have a leisure battery fitted, but would like to add a switch to have on / off for the leisure battery. I would also like to wire the...
  17. R
    Halo roof lining panel
    Hi, I. Looking at installing what I believe to be called a halo roof panel. Just looking for some advice on how to fit it to the main ply panel. If anyone can help I’d be grateful. Russ
  18. C
    Halo Roof Lining
    Hi, I am part way through my conversion and didnt want to go down the pop top route. Has anyone installed a halo roof I think they are called? Goes just below the roof lining. Just wondered if you made your own and how you attached them?
