head unit
  1. C
    T5.1 caravelle exec
    Hi folks, Very new to the group so no doubt this has already been discussed. I’m looking to upgrade a few things on the caravelle, She’s a 2.0 2015 140. I’m Looking to upgrade the following so appreciate any tips or hurdles to expect. Wheels and tyres change from the 17inch custom to...
  2. williecba
    Carplay, Head Unit, Entertainment Centre, Touch Screen, Digitizer, Problem, Dealer Recommended, Repair Company.
    I see that there has been quite a bit of discussion about problems with the touch screen on the head unit. (I have an iphone which I always plug in and I normally use Carplay all the time on even the shortest journey) Firstly, I had small patches on the screen that would not repond. Then I had...
  3. R
    HEAD UNIT 'CUTTING OUT' PROBLEM
    Yes I have a leisure battery set up, but I'm fairly certain it's wired into the main van battery. This is the new head unit, vw compatible dash housing. Not sure about the can bus adapter, but you could be right. It's got me baffled!
  4. M
    OEM H/U: Sell or Keep?
    I have the below head unit which I've removed to install an Alpine unit. It works other than the Android Auto audio issue, so Carplay and everything else is as it should be, but I'm wondering if I should sell it, or keep it? I don't intend selling my van anytime soon, if ever. If people sell...
  5. M
    Swapping Head Units between VW Models
    Hi : New member so forgive me if this is has been covered. I have a 2018 T6 which I suspect had an aftermarket head unit fitted by the previous owner as there are x 2 rear speakers - not connected and an aftermarket reversing camera again not connected. I got the van from a VW main Dealer, I...
  6. M
    No google maps gps signal
    I have look high and low but can't find an answer. So it's like this, i have no gps signal in the T6 it just keeps saying "looking for gps signal" or "re-routing" i have been in my hyundai van today and as nornal no problem it that. it's a Samsung S24 if that helps to shed any light on the problem.
  7. C
    T6.1 Headunit removal: Urgent assistance required
    I’ve started the installation under seat subwoofer in my California however I’ve got to the point after dismantling most of the dashboard. I can’t see how to remove this head unit as in picture apparently there’s some release mechanism but I can’t see where it is. TIA
  8. D
    SD card for headunit sat-nav
    Does the slot on the left mean if I purchase a SD Sat nav card and insert it it will work as a sat nave unit ??
  9. Florry66
    For Sale ZEI - Navigation system "Discover Media" including "Streaming & Internet" T6.1
    Evening all, just wondering if there is any interest in this, I’m having an upgrade at Absolut5 Audio in July and the Discovery Media system with Sat Nav, CarPlay, streaming etc, a £1115 plus vat option, will be available end of July, it will be removed from my 2021 T6.1 Highline with just 15k...
  10. K
    Composition Media headunit value
    Before selling my old T6, I swapped the composition media to a new Kenwood unit due to the right hand side being non responsive to touch. I’m aware that this issue can be repaired but given I no longer have the van I was wondering what the value of the head in it would be in its current...
  11. G
    T6.1 Bluetooth codec
    Another question - who knows, what Bluetooth codec the VW has?
  12. G
    Ringtone too loud
    How can I lower the ringer volume? Regards
  13. P
    RAC Big Orange B’stard - stereo update
    Hi Folks, Newbie here, who has just taken ownership of a 2018 ex RAC T6. I was wondering if there is anything that I can do to upgrade the existing stereo via firmware/software, or do I install the Road Angel DAB unit that I bought for a previous van? Any help would be very much appreciated.
  14. S
    OEM Head Unit failing - repair or go aftermarket?
    Hi All, New member here - nice to meet you! I have a 2018 T6 Sportsline Kombi and have been struggling with the head unit for a while often not connecting properly to Android Auto and needing a hard reset. But the left half of the screen is now unresponsive to touch input so its time to either...
  15. Benh76
    Sold Head Unit from 2016 T6
    Not sure if it works as was given to me with van with upgraded Kenwood unit. Was advised verbally it works but not able to test. Therefore any use to anyone for £20 ?
  16. Deviant Tubs
    Keys in the Ignition - Audio Runtime
    Dearest Hive Mind, I've got a rather wonderful 'Signature' system care of the Audio wizards at @Absolut5 in my T6.1 Setup is Audison Amp under the driver seat with a belter of a JL Sub under the passenger seat. Hertz speakers dotted around. It's a superb system, so much so it seems a shame...
  17. J
    T6.1 Head Unit screen failing - repair or go aftermarket?
    My HU has failed, the screen appears to have stopped working all together. It still lets me plat radio, plus source in via USB C sockets etc and retains all functionality , I just can see any of it ir interact which is far from ideal. The unit has never been great to be honest. The van is just...
  18. T
    Replacement Head Unit recommendations - budget
    Hello, just purchased a T6 and unfortunately the head unit has no BT from factory... Im looking to replace it with an aftermarket one and would be nice to keep just the sensors on the screen and to have apple car play. Any recommendations which one to fit for less than £500. Thanks
  19. U
    Navigated Liverpool - MIB 2 Radio repair
    My T6 MIB2 radio has been getting worse over the last 12 months. At first it was like someone was touching the screen or moving their finger over it. Did a little searching and it’s a common issue on 2016 MiB units I also found some crazy costs and sticking plaster services. A lot of these...
  20. HoopDub
    Head Unit, yes i know do a search....but.....
    Having done a search all the "what head units are available that keep the oem functions like nav dab rear camera and park assist?" But the threads are all what id consider old, a couple of years is a long time in technological terms. So i thought asking again may throw up some different newer...
