head unit quad lock
  1. C
    T5.1 caravelle exec
    Hi folks, Very new to the group so no doubt this has already been discussed. I’m looking to upgrade a few things on the caravelle, She’s a 2.0 2015 140. I’m Looking to upgrade the following so appreciate any tips or hurdles to expect. Wheels and tyres change from the 17inch custom to...
  2. D
    Aerial cable identification
    Hi Replacing the head unit with an android one Can someone please confirm what each of the aerial cables are there are 3 connections in total. Current unit has no sat nav but does have FM and DAB radio Thanks
  3. R
    [Resolved] App Connect installed but CarPlay doesn’t start
    New to me T6 2018 Have Discover Media Pro. Have this screen. However when connecting iPhone, the phone charges ok but the above screen doesn’t change and CarPlay doesn’t kick in? Nothing happens. I’ve tried: 2 genuine cables 2 iPhones Head unit Factory reset The USB next to the...
  4. Pleh
    Quadlock for amplifier in T6
    Hi everyone, I wasn't able to find this topic so I am opening a new one. I have VW t6 from 2018 with rear speakers, could someone tell me if there is a quad lock harness that enables me to connect the external amplifier via 2 RCA connectors? I wasn't able to find this quad lock connector...
  5. S
    Reversing camera stopped working after headunit removed
    Pulling my hair out with this. Have a T6 with a retrofit vw composition headunit that has CarPlay enabled and a genuine reversing camera. Recently the touchscreen went (common problem) so I removed the unit and sent if off to have a new touchscreen fitted by a guy who has done a previous unit...
  6. The Tango Van
    Atoto F7XE headunit in T6 Transporter
    Dropping a few notes in here as I just finished fitting an Atoto F7 headunit to my T6 Transporter and it was tough getting DIY details. I bought to Atoto F7XE unit from Amazon and I figured it was worth an effort trying to fit it and have wireless carplay and 10in screen for a fraction of the...
  7. Steve1978
    Looking for wiring layout for stereo.
    As title says looking for colours of speakers, perm live and switched live. Many thanks
  8. sipep
    Is this what the t6 audio connection looks like?
    Hi I have purchased a used android headunit. He says it fits the harness that looks like the attached. Is this this connection the same as a 2019 t6?
  9. A
    A 'different' fader problem - wiring
    I am hoping someone can help me. Our van is a 2017 T6 Trendline with a standard 'ICE' head unit. Rear speakers were wired in by the campervan converter. The rear speakers respond to the volume and balance controls, but without fader. My son has recently used a PC to enable the fader function...
  10. D
    Discover Media rear connections
    Hi Can anyone help me with identifying the connections on the back of the discover media unit. There are 4 colour coded (pink, black blue and yellow) aerial type connections and a 4 pin connection which I think might be for the usb. Reason for the question is I am trying to fit a Kenwood 9720...
  11. Cnud
    Sold VW T6 Quadlock Harness To Add Amp / Sub & Rear Speakers
    Travelin-lite VW T6 Quadlock Harness To Add Amp / Sub & Rear Speakers No rear cabling supplied just the output wires (green and purple) £40 posted Or collection from NG13
  12. T
    Wiring a new stereo - ready to poke my eyes out.
    Hi, Can anyone with more stereo wiring experience than me (most!) chip in with some advice? I impulsed bought a use Android unit from a local clearance aution for the wifes van. Regretting it. I had to by an ISO adapter for it - its a 2012 T5.1. Swapped all the various connectors & plugs over...
  13. Saffa365
    Quadlock extension
    Hi Guys I’m trying to understand the wiring loom . Does anyone have a link or know what I need to put an extension on my current wiring harness . There seems to be loads of different quadlocks out there It’s 2016 highline with mfsw and rear parking sensors Cheers
  14. Tsixty
    Rear Speaker quiet
    Help! Going round in circles. Installing Skipton rear speakers, these come with a plug and play harness so you don't have to put the rear speaker pins in the quad lock connector. Have enabled the rear fader using OBDEleven according to some instructions found on the forum. Fader is working, but...
  15. SteH
    Blam RA 704 DSP PRO LOOM
    Hi looking for help if possible, had the Blam amp fitted to my 2011 transporter but removed prior to selling as it a top quality amp. I’ve now got a new 2021 Transporter but the Quadlock is different but I still want to fit this is possible. Tried the original supplier but got no response. Does...
  16. Bluemerlin
    Installing Aftermarket reversing camera to an OEM head unit.
    Good morning all, first post on here but have been using this forum for guidance for some time now, and thank you to @Pauly for accepting me. So he is where I am, I’m looking to install a wired aftermarket camera from ADT and fit it to my OEM composition media head unit. However finding it...
  17. Skyliner33
    Head Unit Wont Go Back In
    I can remember seeing posts about fitting head units but for the life if me I cant find again. I've fitted one of these to the back of the head unit: Now I cant get it back into place : Any tips or tricks Im missing? Thanks.
  18. RattyMcClelland
    T6 Quad Lock Wiring?
    I attempted to fit my Alpine X801d-u with the 801t5 plug and play kit. Wasted 2 hours. It didn't plug and play at all. The internet lies. What are these wires. I'm holding the alone wiring harness. Is misses a fair few cables. The blue and green oem wiring blocks are completely missed...
  19. W
    Highline Audio Upgrade Wiring For Kenwood Dnx7017
    I’m seeking some advice on the wiring for upgrading my factory unit to a Kenwood DNX7017DAB. I’ve identified some of the cables in the quad lock on the van, but could do with some help in identifying the extra coloured blocks. The van comes with Park Assist and Steering Wheel Controls as...
  20. Mickymiff
    Discovery Media System - no rear output
    Why is there no rear audio output on the bsck of my discovery media system? I.need to wire some rear speakers but have no output! Any ideas??
