headlight adjustment
  1. B
    headlights not aligned properly
    Hi everyone, First time post from an idiot when it comes to all things car like:). I've got lots of tips from you guys.... Thanks I've had an issue with my T6 Multivan headlight's beams being misaligned. I explained to the service team in Sydney, AUS the last time it was serviced there (mistake...
  2. D
    T6.1 H15 Halogen High Beam Headlight Alignment Adjustment
    Can someone tell me how to adjust the alignment of the original H15 halogen high beam headlights in a T6.1 van?? Having fitted LED bulbs, I want to lower the DRL and High Beam slightly because they are too high. I’ve spent hours trying to find documentation to show what screws / where the screws...
  3. BennyBoy
    Dipped Beam Adjustment
    Hello Is there a way to adjust the starting point of the dipped Beam bulb when it is set on 1 on the internal dial? I'm not looking to lower but higher the bulb just a little as when I compare the range of them to other vehicles they are considerably lower even when set on the highest...
  4. AshM
    T6.1 self levelling headlights with air ride
    Hi all. Wondering if you can help. Recently had my transporter with accuair elevel+ fitted Now it's getting dark early I noticed the beam is so low I'm having to use full beam most of the time. I've only drove it around 3 times in pitch black and straight away I thought this can't be for real...
  5. roooms
    Headlight aiming fault in Carista
    Can anyone suggest what this may be? I can reset in Carista and hear some (headlight?) motors moving but then the fault returns immediately.
  6. T
    Headlight level switch not working with H7 [Resolved]
    Hi, I have travelin lite led headlights on my t6 and noticed this morning that the headlight level switch is no longer working when I tired to adjust them. I noticed that the dash light adjuster is still working and if this is part of the same switch unit would rule out a blown fuse ? If anyone...
  7. T
    Headlight beam Adjustment
    Hi, I uprated rear springs as the back end was drooping, as a consequence the dipped lights are running low, not projecting far enough no matter what position the adjustment roller is set ot in the cab. What is the formula for heights and the adjuster locations? assuming i use the garage door...
  8. G
    Travelinlite Headlight beam adjustment
    Hi all! I’ve recently fitted Travelinlite T6 Headlights with dynamic LED indicators, LED DRL, but halogen H1 & H11 bulbs. What I can’t work out is how to adjust the beam so they are level & not only lighting 2m in front of the van. Anyone fitted & adjusted these before? If so, can you post a...
  9. W
    Autoranging Light Sensors
    Anyone know where the sensors are and what they look like ? My lights are too high.
  10. Keaney
    LED Headlight Adjustment
    hoping someone can help, my vans on air and at a low cruising height if I’m stuck in traffic and pull forward it flicks the headlights up and pretty much flashes the car in front. Also found driving around it’s going up and down all the time. Found quite a bit information about adjusting them...
  11. Loz
    Loz submitted a new resource: Headlight Adjustment - Workshop procedures for headlight adjustment and alignment. Read more about this resource...
  12. Loz
    Headlight Adjustment 2017-11-08
    A section of the VW workshop maintenance manual dealing with the adjustment and alignment of headlights on the T6.
