headlight switch
  1. Samiguel
    Headlight rotary switch error check help please.
    T6 Highline, 2018, H4 lights, rotary switch with the automatic setting. So, the genesis of this issue was a long drive home in the fog on Sunday. Used both front and rear fog lights for the first time in ages and the lightbulb warning light came on the dash - assumed it was one of the fog light...
  2. CJW
    Headlight switch stuck
    Hoping someone can help. The usual ‘push in, turn one stop clockwise, and pull towards you’ trick isn’t working for getting the headlight switch out. I’ve tried every which way, gently, more or less rotation, giving it a wiggle [stop it] but it’s stuck as a stuck thing. I can’t get to the back...
  3. J
    Headlight switch problem?
    Hi guys, I’ve just fitted a halo 9 and ran the gps to the a pillar on drivers side, (removing trim and headlight switch) whilst doing this I also replaced the interior/courtesy light switch, now headlights are permanently on, (no change on switch from DRL to headlight) fog light doesn’t work...
  4. AshHT6
    Thq v3 drl headlights install (ebay bargain?), is the sidelight switch position redundant now?
    Hi, I've just installed these v3 drl headlights (I think they are THQ? Got them off Ebay for a great price of £210.99 delivered (used without bulbs and missing a fixing point and location pins on one light) I fitted them without issues and did a fix for the missing fixing point. I've installed...
  5. A
    Dashboard display and auto headlight not working
    Hello all, first post here so hopefully this is ok. Yesterday when starting my T6 2019 - at night the headlights didn’t automatically come on - just side lights - and this is how my display looked. I couldn’t read the dials, just these red lines. I manually turned on the headlights and had to...
  6. The Flying Scotsman
    Headlight switch cable identification
    I’m still trying to sort the issue I’ve got with my THQ lights. I’m pretty sure I know what’s causing the problem. There has been 2 wires tapped into the wiring going to the light control switch. A red and a blue wire. I’m not sure what they are for and I’ve spoken to the company that...
  7. S
    Merhabalar, t6 far açık ikazı
    Sol sürücü kapısı açıkken far açık yada kontak için ikaz sesi gelmiyor. Ne yapmalıyım?
  8. W
    Headlights on, rotary switch doesn’t confirm
    On my 2016 T6 I have automatic headlights that turn on when it gets dark etc. The only way I know they’ve turned on is if I glance over at the hazard light switch to see if that is illuminated. I notice the rotary headlight switch illuminates when the sidelights are activated, but not with the...
  9. C
    T6.1 headlight switch - warns when sidelights left on
    I have a question around the audio beep when leaving lights on in a t6.1. It’s a startline without auto lights. I have noticed that if I leave my side lights on take key out of and open the door it beeps to warn me I have left the lights on. But if the switch is set to full headlights and I...
  10. C
    VW t6.1 startline auto headlight retrofit question
    Hi, I want to retrofit the auto headlights feature to my t6.1 startline. From reading the only other post I can find in this forum about it, it seems the people who have tried just changing the headlight switching module (like you needed to do on the t6) to one which includes the auto function...
  11. revdecal
    Headlight issue THQ H7
    Anyone had this problem before? If I have the lights switched to auto the LED on the left headlight does not work. If I turn the headlights on generally they seem fine so the LED clearly works but no longer on 'auto' mode which is weird?!
  12. fezza68
    Auto headlight switch help.
    Hi all. Is there anyone in the manchester area with auto headlights on their van and start stop who is willing to help me out?. Mine has developed a fault where the front fogs have stopped working on the switch. I wanna try another headlight switch to see if thats the problem before i buy one. Ta.
  13. Octane85
    Headlights not in tune with switch [Resolved]
    Just bought a T6 and one of the things I’ve come to find out is that the headlights don’t seem to do what the switch is asking them to. With the switch set to Auto they work as expected. However, here’s what happens in other modes: Switch: Off = lights: full beam Switch: sidelights =...
  14. marty NCL
    Auto light sensitivity
    Hello all. Has anyone else had the minor annoyance of auto lights being indecisive? I often find that minor changes to light, even just cloud cover, when driving in conditions that I would consider still very bright, will cause the auto headlights to switch to dipped beam. Is there a value...
  15. JiMsHaDY69
    Help! Trim under dash below headlight switch
    Stumped on how the trim panel below the headlight switch is refitted? My issue is getting the trim under and around the circular headlight switch as the the courtesy light brightness/passengers on board switch stops the trim going in under the circular switch. Couldn't find anything relevant...
  16. T
    Auto headlight switch retrofit EU6 T6
    Greetings, I purchased a golf mk6 auto headlight switch (small connector). Arrived in 24hrs and fitted perfectly, ran sensor under a pillar trim and is a neat look. All functions work out of the box - no need for a £55 one from Transporter specialists. DRLs are on, sidelights added at dusk...
  17. Savgav1
    Chrome headlight and mirror switch's
    Hi guys does anyone know if you can get silver/ chrome headlamp switch and mirror switch to match to window switches on vanx with silver tips.
  18. Rosski
    Headlight & DRL instrument light
    On my T6 I can see a headlight symbol on the instrument cluster but it doesnt illuminate when the headlights switch on. Neither does the symbol on the rotary headlight switch, either. I know the dashbaord switches illuminate but would really like to enable the cluster symbol if possible. I've...
  19. Martin955
    Headlight switch removal
    I've looked at the videos, but mine won't come out. The switch has lost its set points it just rotates round. I have exposed the underside of the switch & pushed up the retaining tag but the switch still won't come out of the housing. Any suggestions?
  20. TEESIXY
    Fog lights and the Headlight rotary switch
    I dont use my van much, and tonight was the first time in ages i was out at night and needed to put the fog lights on. The only way you can do it on mine is to rotate the switch clockwise two notches from its usual auto lights position, and then pull the switch out to turn them on. The...
