heat shield
  1. Dubious
    Thin metal cover underneath of t6.1
    Hi all, I hit some flood water a bit fast on Friday and it seems to have damaged part of the underside of my T6.1. There is a piece of thin, flimsy silver metal hanging down. I’m unsure if it’s a heat shield or a protective element. There seems to be a single piece down either side of the...
  2. M
    Gearbox Rattle
    Just wondering if anyone has had the same problem I have recently had with my van, its only got 20,000 miles on the clock. So, I heard a rattle at low speed in 1-3 gear, you could only really hear it when driving through built up areas where the noise had something to bounce off. Took it into VW...
  3. I
    HEATSHIELDS HELP
    Hi hopefully someone can help. I am looking for a picture / diagram of the underside of the van or even better the layout for heatshields on a lwb t6. I stupidly took them off to fit a water tank and didn't mark them. Not I cannot remember which on goes where. Any help will be great. Tia
  4. Garny999
    T6.1 Undertray Panels.
    Hello, I was about to venture into fitting a diesel heater under my passenger seat. I had a sneak peek at the access from underneath (undertray)for mounting the unit and running the ducting. The question I ask is....does anyone know what this lot is and is this also on a T6. I am thinking that...
  5. Ads_Essex
    Sold Heat shield glass-fibre cloth + tape
    Heat shield glass-fibre cloth 1000mm by 350mm Roll of heat-shield tape (unmeasured but was 25m by 50mm). Free to VIP, just pay postage.
  6. X
    T6.1 floor heating up!
    Hi, after slowly advancing in a long queue for about an hour (DSG 4Mo with stop-start switched off) I've noticed significant heating of interior floor - especially rails - were so hot, one couldn't step barefoot on them. I was told, that this has to do with cooling of gases for AdBlue system...
  7. Sturge
    Heat Shield Loose
    Hi Just got my van back from bodyshop, and not sure if this is how it looked before it went in to them. I dont recall seeing the heat shield here before? Can someone compare to their van? Thanks
  8. michael thorpe
    How To Remove These From Heats Shield
    can anyone tell me if the underbody trim have trim fittings as well taken all the fasteners off that i can see and still not move.
  9. Andrew Wilkinson
    Underslung Water Tank Melted!
    As part of my conversion I've had an under-slung fresh water tank fitted to my T6 LWB. It's the long slim tank which fits next to the exhaust almost down the centre of the van. The first one a I had fitted was not very secure and melted against the exhaust. I have since built a more secure way...
  10. Walski
    Plastic under tray for engine
    Hi All Bit of a frustrating conversation with my dealer today. My panel van was delivered without the under tray which is the protection panel on the underside of the engine. I spoke to the dealer who said they would fit the panel when my van came back from the dealer. I contacted them today...
  11. Wills
    MY18 exhaust design
    1st time under my van today to remove the spare wheel so it doesn't get pinched and drill the holes for the Cali seat rails. Looks like some one's pinched the rear section of the exhaust system.. When did VW decide to shorten the system so it ends halfway along the van?
  12. ChrisFrench
    OEM plastic underbody trim/covers
    Can anyone help with this issue I have with the front black plastic under the van covers. These are all down both sides underneath the van. I need a new one for the front off side. Probably been hit by snow/ice and has been well and truly busted!! Has anyone removed these permanently ? I can't...
