Hi guys, recently bought a T6 highline and noticed it doesn't have heated mirrors. I take it there is no easy way other than fitting and wiring in a complete new set up? Slightly annoying as i thought being a highline it would have been standard.
Hi Guys.
I know this has probably been asked multiple times but does any one have access to a parts diagram or can help with some part numbers as I can find what I’m looking for.
I had a couple of things flagged on my mot on my 19 plate Sportline last week that I would like to get sorted:
Hi all. I've recently bought a 2020 t28 startling and the heated mirrors don't work. But I'm struggling to find which 1 to check. It's still warrentied but I live 100 miles away. I was hoping to save the drive if its only a fuse. Any help would be appreciated
Realised this week that neither of my heated wing mirrors are demisting. They both adjust ok on the control knob but nothing when I turn it to demist. I have plugged my Carista in and looked at mirrors and they are set as yes to come on with the rear demister. i don’t have a rear demister and I...
Just noticed a problem witht the new van (2016 T6 panel van)...
Nearside mirror clears fine, but drives side doesn't.
The glass is warm to the touch on the nearside, but not as warm on the drivers.
I have measure the voltage and it's fine, but resistance of the nearside mirror is...
I'm just about to fit the two wires to my heated wing mirror glass (brown & white), I've stupidly forgot which way round to connect these.
Brown at the top, or the bottom?
I recently had to replace my entire drivers side wing mirror. (Replaced with genuine VW Parts)
It's manual fold with electrical adjustment.
I have adjusted the mirror fully over to the right and i am still looking at the side of the van. When I was on the motorway I couldn't see the lane next...
Electrically Controlled Exterior Mirrors Circuit Diagram
Includes mirror controls, mirror heating and lane change assist warning lamps
Does not include radio/infotainment aerials
I have a July 17 delivery T6 Panel van and recently noticed that the heated mirrors are no longer working. It's a trendline so i don't have heated windscreen or heated rear window. Does anyone know which fuse this may be linked to ? I'll be honest in that I leave the heated mirrors on all...
hi every one.
my heated mirrors on 2016 T6 are not heating up anymore. when i plug vcds in and test the output, they work fine.
its had a new switch fitted, im assuming the fuse and relay is good, but maybe a bad connection between the switch and the mirrors, its both mirrors that are not...
Bought my 2017 T6 back in the summer so at the time I didn't even think to look. Now that winter is here the heated windscreen is great but there is no option to turn the heated mirrors on. Am I missing something? Or is it just the case they aren't heated? Would seem a bit odd to have a heated...
Just for information/observation. I used Carista to enable the heated mirrors to come on when the heated rear screen is turned on. This worked. What I wasn't expecting was that if you do that the mirror heating position on the mirror knob no longer works. I was hoping that changing the setting...
T6 steaming heated wing mirror problem.
I recently aquired a 2018 T6, i noticed this morning that when i put the mirrors on heat the right one demists quickly with no steam coming off it, the left one however take 10-15 mins longer to demist and steams like a kettle. it doesnt look broken or...
Having read this thread about bad radio reception - T6 Aerials, Gps, Dab, Fm/am, Gsm - How I Did It and knowing that my offside wing mirror is not body colour (as it should be for a Trendline) and was not responding to the electric controls, I decided to take the mirror apart.
Thanks to folks...
I was under the impression my wing mirrors were heated. Had a 1st frost this week and when came to flick the switch to heat there was nothing there :laugh: (no icon like was on my Caddy) , its something i've never took any notice of since owing the van.
Am I missing something or are some wing...
I should have never have got this van. Always liked hacking about with stuff but the most expensive thing I've generally messed with is a fridge! Then I got a T6, bad idea.
So I have installed a GSM relay into my lesuire electrics. I can trigger 4 different circuits from an app and have 2...
Following on from a number of threads over the past week relating to heated mirrors, and how they are on a separate switch (on the mirror control stalk). I have had mine hooked up to VCDS today and was playing whilst getting an oil service. There is a code in VCDS that enables "mirror heating on...
