I have a T28 Highline 2017 plate and it looks like I have a heated windscreen. I bought it second hand so not sure if this is standard spec. There isnt a button or switch to turn it on! Of course it might be the rain sensor circuit but new to these so not sure.
If it is a heated screen is the...
Hi lads
Can anyone who has T6.1 and heated front windscreen button on screen display share addmap for address 5F please :)
Trying to enable it in mine but having no luck finding it in adaptations, so hoping to find by comparing someone elses.
Thank you in adavance
Stan
Recently had the windscreen replaced on my MY23 Highline Kombi-based camper. During replacement, the rubber wind-deflector for my Hilo Sport pop-top (which is stuck along the top edge of the windscreen) was removed, so I have refrained from using the van until I could arrange for a new one to be...
Well that's just typical! The 3 year warranty on my T6.1 ran out a couple of weeks ago, I fired up my van this morning in a heavy frost to find a 1 foot section of the heated screen has failed, on top of the other 2 single wires that had failed a while back.
Before I pull anything apart, or just...
Just investigating why my t6 heated screen has never worked and notice what appears to be ribbon cables snapped on both sides. Anyone know whether these are easily replaced?
I have this trickle of water appear when it rains down in the drivers foot well. Any ideas where it is coming from? When I look up above the pedals I can't see anything else wet?
I don't have roof rails just a West Dubs pop top. All drains seem to work under the van.
Thanks,
Matt
My 2020 T6.1 has a heated windscreen which doesn’t appear to work. It’s been into VW and they can’t find any obvious faults with it. The last vehicle I had with a heated windscreen would clear the screen in about 30 seconds. In the T6.1 if I turn off the blowers and turn on the heated...
While I was removing an old inverter supply cable and fuse in the battery tray I found this cable lying at the bottom.
Anyone shed some light on what it might be, where its from and more importantly do I need it?
Cheers
Hey all,
I'm annoyed at myself that I forgot to spec the heated windscreen in my new van.
The only thing is, I notice that the windscreen itself has the heating element running through it.
Is it a big job for someone to fit the relay and switch on the dash? Or is there a lot more to it than...
When lowering my van the other week me and @Kyle lannerz discovered this cable in the o/s upper strut cavity. I have tried to plug it back in but it is 2 male connections there
When plugging the van into Carista it is showing a rain/light sensor fault is it something to do with that?
I am 99% complete on my heated screen retrofit, it all functions fine just not quite the way I want.
it will work via the separate button setup as most of them are But I want to control it via the climatronic panel over CAN
(You can just make it out on this pic)
as mine is a T5.1 I have a...
Had my heated front windscreen replaced a few weeks ago and now only the passengers side heating works. Fuse keeps blowing on the drivers side. Have seen the wiring diagram and looked at the connections but newish to the transporter world so not sure if it is connected properly.
Can...
Never had a heated windscreen before, but pretty sure it's not designed to work like this.
Can someone confirm that it shouldn't leave a strip of ice.
The van is only 2 months old so should be covered by the warranty.
Hi all, I’ve searched and downloaded the fuse layout but to be honest quite confused as to which fuse it could be for my heated screen. Can anybody help as it’s not working at the moment
or does it just take sometime to warm up?? I ask as we used to have a ford and the screen was instant
thanks
Hello,
I have a Caravelle T6 from 2016.
I'm using it in Lapland during the winter. It's cold, and very cold... :D
I need to use the defrosting windshield (I have the option), but the timer is too short for me, I need to push the button too often.
Do you know if it's possible to change de...
Hi, so with the cold weather being here I have used my brand new T6's heated windscreen. However it doesn't work or at least half works. clicked the button and the near side works fine and feels hot, offside is cold to touch and didn't defog or defrost windscreen.
Any thoughts or trouble...
I havnt had the T6 long, so this is the first time I have had a chance to use the front heated screen option as it was a bit misted up this morning.
However, in a few seconds I could see a problem, see picture below (taken badly) where only half of it is working. typically the fault is on the...
