The heater controls on my dual zone HVAC on a T6 Caravelle has failed with the heating stuck in, I managed to manually turn it to cooling over the summer but now Autumn is approaching I could do with sorting it.
Couple of questions, 1 - does anyone now the model number or how I can find the...
Hi all, just wanted to raise awareness of my actuator arm that I’m selling on eBay. I’ve sold a few now and use it myself and haven’t had a complaint yet. So if you’re in need of a replacement, please consider mine.
EBay item: 266785568556 £35 + £P&P...
I have a T6.1 Startline (2020) model that is delivering a set warm temperature no matter where I turn the temperature dial to.
Having removed as many panels as I could from the Drivers side I have taken the below picture.
I have followed a previous thread to investigate the control arm under...
T6 right hand actuator control arms custom made in aluminium
I have been through many plastic ones, done the recalibration many times with all sensors reading correctly but Still breaking arms, so I had enough and designed and made my own from aluminium,
These have been tested on my own van...
I have a problem with my 2018 T6 with the actuator arm which had broken. I have replaced the broken arm and it did the same again. Purchased a new actuator and it broke again as it is trying to drive the arm passed the end stops. I have connected to VCDS and it shows it exceeding the end stop...
Replacement actuator arm for T6 heater controls.
Attached pic shows original white arm (not included) and a modified stronger version for a fix of a common defect.
If interested please contact Tony on 07880620367.
£35 first class signed for postage included (signature required) UK Only.
Newbie here, so apologies for any idiocy. Drivers side heater not working. Still blows air fine but only cold! All others working fine, passenger side and the all the back (have a T6 shuttle). Can’t work out why the blower works but no heat and only a problem on the drivers side. Took it to VW...
