heater support pump
  1. T
    Heater Support Pump and Voltage error woes
    Put the van in for a heater support pump error with a specialist. It has the following errors (starts off supply voltage eventually throws an EML). Put it into a ‘specialist’, and asked them to check the wiring and supply voltage first. They called and asked if I wanted them to change the...
  2. mmi
    [T6_measured] 01-Engine - Built-in tests for electrical coolant pumps
    Yet another set of engine's built-in tests to try. HOW-TO run engine's built-in test for EGR cooler pump IGNition ON (engine not running) VCDS > Select > Engine > Output test > IDE00879-EGR cooler pump Select "Measuring Values" Pick up e.g. the following data items for monitoring - the same...
  3. T
    Another puzzle to solve…
    Seems like my T6 loves my attention recently. 2 years trouble free and the past month its been a pain in the ass! I had an EML come on this week. Had a look and have the following: Assume these three are not a coincidence and are related. Reference voltage error, heat pump error...
  4. S
    Engine management light and emission control lights on
    Hi. First time poster. Recently bought a 2017 T6 converted camper 122k on clock. Out in it today and the engine management light came on and noticed not much acceleration in 4th 5th or 6th gears. Not much later the emissions control lamp came on. With same issues. Decided to turn around and...
  5. JordanGT
    Fault Code 27167
    Just driving home and engine management light came on. When I have scanned with my Carista I have also see this code come up 27167 but no clear indication what it is or why it won’t reset.
  6. Samfisher
    Continued water circulation pumps running - Flat Battery (Resolved)
    Hi Guys Still have a problem with the battery going flat over night. Its getting a bit embarrassing when I pull up to a job and flip the bonnet to disconnect the battery !!! Anyway had a bit of spare time today and the drain is 0.3 amps, I have pulled some fuses to isolate the problem and if I...
  7. BigYoeKing
    Faults cooling system EGR
    hi guys, i got errors p2457 and p16cb00 on my t6 75kw. you have no idea what the problem is? egr cooling pump? fuses are ok. Thank you
  8. B
    Carista codes help please
    Just purchased a Carista unit as I had the engine management light come on. The codes I have come up are P16 BF and P16 CB I cleared them to get me through an MOT but they have now reappeared, when I google it it comes up with faults but not specifically for a T6 anyone have a clue what they are...
  9. rmo69
    Auxiliary Coolant Pump Failure
    Engine management light on again, Back at dealers again, No courtesy vehicle again, Missed deliveries and pissed off customers again. Apparently the 2nd auxiliary coolant pump has failed. Moral of the story? If you don't want to be a VW R&D guinea pig, wait at least two years before buying a...
