high beam assist
  1. WILDTHING7
    High beam not working
    Hi can somebody help me with my high beams not working When I go to flash anyone it just stays on and I have to turn lights off for it to go off ? Any help would be great?
  2. A
    Module 20 / High Beam Assist
    Buongiorno a tutti, scusate se sbaglio sezione del forum ma è la prima volta che scrivo. Non riesco a trovare i settaggi giusti per accensione/spegnimento automatico dei fari. Appena attivo si accendono gli abbaglianti ma non si spengono quando incrocio un'altra auto. Ho questi parametri IDE...
  3. G
    T6.1 Retrofit high-beam assist and traffic-sign assist?
    Is it possible to retro fit auto high beam and traffic sign recognition to a T6.1?
  4. JamesWebb
    Sold High Beam Assist rimless mirror for a T6 (NOT 6.1) . . .
    Hi there, I have a rimless mirror (7E0 857 511 G 9B9) for a T6 (and not a T6.1!) which I bought new, by mistake, for my T6.1. It won't work in the 6.1 because of the different can-bus protocols in the two variants - but it will work if you have a T6! Included is the bezel with the hole for the...
  5. M
    Can I use MQB HBA mirror to T6 PQ25 ?
    The answer is...You can but it's not easy. I told my experience if someone want to do this I follow this thread instructions. The adaptions set is possible only Odis ( maybe also VCP not tested) because VCDS can't set all channels. Odis adaptation set method is different. I use Audi A3 mirror...
  6. JamesWebb
    T6.1 HBA retrofit . . . ?
    Hi there, Can you help with this? I purchased a HBA retrofit kit, not realising it was for a T6, whereas I have a 2021 T6.1 - my bad! :eek: I've had a quick look on the forums for help but can't find any specific 6.1 instructions re wiring and coding. So, would you happen to know . . . a) if...
  7. Dayoster
    For Sale T6 High Beam Assist Retrofit Kit
    Im putting a High Beam Retrofit kit together including everything needed to do the conversion on the T6. All parts brand new and genuine. Highline rimless mirror (looks amazing). New mirror cap for the bottom (with the hole for the camera) Additional 2x can wires for connecting to canbus...
  8. superquadro
    High beam assistant
    Hello everyone, I would like to install the lights wizard, I found a mirror of Skoda kodiaq reference 565857511B on eBay. The seller says it’s also for a T6, you think it’s compatible?
  9. Y
    How to activate Adaptive Lane Guidance in a T6.1
    I have Lane Assist in my T6.1 and I expected it to be like a semi auto pilot by keeping the car in the middle of the lane. Instead it just ping pongs between the lines of the lane. However it seems like it is possible to enable Adaptive Lane Guidance which will keep the car in the centre of a...
  10. marsie
    Has my van got high beam assist?
    How do I find out if my van has High Beam Assist. Its a 2017 (67) highline with factory LED headlights but not sure if it has high beam assist or not?
  11. Vito Ciampa
    High Beam Assist not working
    abbaglianti automatici (LED) ciao a tutti, ieri sera mi è successa una cosa strana, il mio T6 ha gli abbaglianti automatici (led), che viaggiano sopra i 60 km / h, gli abbaglianti si accendono automaticamente, ma non si spengono più se in senso contrario uno all'altro veicolo, cosa pensi che mi...
  12. Pauly
    T6.1 Front Camera (HBA) Wiring Diagram 2020
    Wiring diagram for front camera built into interior (rear view) mirror, this is for high beam assist/main beam assist camera only For front camera for other assist systems check this document instead - T6.1 - Front Camera For Assist Systems Wiring Diagram VIP Membership is required to download...
  13. Texxaco
    high beam assist lowering speed activation via OBDEleven
    Morning all, Can this be done via OBD11? If so can someone show me the way. Thanks for any help you can offer.
  14. bullracing
    Retrofit Auto Dimming/rain And Light Sensor Mirror.
    I have this vw style auto dimming mirror with light and rain sensor. Where can I find the part numbers to see if it will be compatible? Does anyone have a picture of theirs without high beam assist?
  15. Spookybear
    [Guide] High Beam Assist Retrofit - How I Eventually Fettled It :-)
    Hey, Just finished my HBA install. Pretty straightforward in the end so thought I'd post a how-to.. Can I say, I love the look of the Rimless mirror, very posh looking lol Cheers go out to @mmi for the comparison scans to see what changes needed to be made & @Robert Mirror purchased from a...
  16. Spookybear
    High Beam Assist Help From Someone Who Has It - Mirror Part No' & Vcds Scan Req'd
    Hey gang, I want to fit HBA to my Six. Is there anyone out there who has it & wouldnt mind taking a pic of the bottom of the mirror to show me the part number so I can try to track one down. Also if you have VCDS, any chance of a full scan to see what the coding is. I think I have figured out...
  17. L
    High Beam Assistant Retrofit Coding Help?
    Hello fellow T6 drivers! I have try to do HBA retrofit but missing some coding because my car won't do anything automatic to high beams. I have a used mirror with HBA camera and correct wiring for it. I did add FLA ecu to gateway and it shows no faults and status is active but I cannot find...
  18. K
    Foot Operated Headlight Dip-switch
    I have a T6 Transporter now one year old and I'd appreciate advice about how I might install a foot operated floor-switch to control headlight switching between low beam and high beam. I'd prefer that the floor-switch operates in parallel to the hand-operated switch on the steering wheel stalk...
  19. Adams
    HBA Retrofit
    I finally got around to having my T6 heated windscreen installed with RLHS mount (albeit on a T5.1 but it’s the same in principle) Works like a charm 5557F2F6-A01A-464D-9E69-BF7F4F039ABC by Adams posted 9 Oct 2018 at 22:37 416CCABD-0942-4C62-BCF7-58C43981F9B8 by Adams posted 9 Oct 2018 at 22:37...
  20. 5557F2F6-A01A-464D-9E69-BF7F4F039ABC
    T6 HBA mirror
