ignition live
  1. M
    T6.1 12v Socket Switched Live
    Looking for a guide on changing the 2 dashboard 12v sockets from permanent to switched live. It's not critical but would just prefer switched so I can leave things plugged in. I know it's not as simple as swapping a couple of fuses and I know there are variations depending on how the van is...
  2. T6 Owl
    Garmin Rear Dashcam Wiring
    Hi all, I have just purchased a Garmin Dashcam Mini 2 to use as a rear camera in my T6. I have also purchased the Garmin parking mode cable to wire it in permanently. However I need to find an ‘Accessory 12v’ feed, i’m presuming this is a switched/ignition live? Where would I find a switched...
  3. B19DRG
    CTEK D+
    Hi I'm just after a very quick bit of advise , I have tried the search function on this but no answer ! So in brief I'm moving across from the AGM instillation done by Sidepods many years ago and heading into lithium , now I know my Ctek is an old model with no Lithium profile and will be...
  4. S
    Victron Smart DC-DC 12/12/30A Isolated Charger with Smart Alternator?
    Hi Guys, Been reading a few threads looking for settings. I have a Victron Smart 12/12/30 isolated charger and the van has a smart alternator. Both negatives on the isolated smart charger are connected to ground (not sure if that makes a difference - but wanted to check). Smart charger is...
  5. z1ts
    Ignition Live under passenger seat (30 amp) ANOTHER WAY TO DO IT!!!
    This much needed and never present function can be now be done without running additional cabling :cool: This is the list of requirements:- VCDS (possibly could be done with other software tools, but I used VCDS) 13 pin OEM towbar electrics (I have full OEM towbar install not just towbar...
  6. T
    T6.1 reversing cam - red wire to which fuse?
    Hi I’m new on here just wondering if someone could shed some light on where the red wire for fuse box goes for oem reverse camera for t6 it said middle row sc-18 but the fuse box is different on t6.1 everything else is done apart from red wire to fuse box
  7. Leekyladd
    New to this forum and the world of vw transporters.
    Hi all …Looking to install the Ctek to my t6 , does anyone know where I can find the ignition switch live for the smart alternator? Any photos would be great also ideas of routing the cable from under the drivers seat. Thanks I’m new to this world of converting vw transporters so I’m pretty...
  8. T
    D+ or Engine Run Signal for DC - DC charger.
    Hi All, I'm a new member to this forum and my problem is how to pick up a suitable engine run signal to activate the DC to DC charger. A couple of members suggested a new post but they did say that I could pick up a 12 v o/p from the central fuse box. However I have no idea which fuse and how I...
  9. Deaks
    [Merge] IGN/Switched live in engine bay
    So I just fitted some swanky new spots on to the A bar and they look great.The spots have these nice DRL strips in each side and my plan was to tap into the DRL feed from the R/H headlight connector, This tap worked great for main beam and for the Sport DRL into dipped beam, but the Headlight...
  10. Samro
    T6.1 12v socket permanent live
    My T6.1 appears to have permanentlylive 12 cigarette sockets. (I didn't have a factory fit leisure battery.) Where is the best place to get an ignition switched live?
  11. T
    Swapping from OEM 2nd battery to dc-dc. What to do with the VSR / relay
    I know this subject has been covered to death but I don't know what you do regarding the OEM relay. So my van had the 2nd battery and I am planning the electrics going forward, I am going to put a lithium under the driver's seat hopefully and use the OEM wiring. So what do you do with the...
  12. J19WMK
    [T6] Ignition Live wiring at fusebox
    I’ve seen so many posts asking about wiring in an IGN cable. And to be honest it was really easy. I grabbed a cheap multimeter and done some checks, now my Solar & DCDC charger is wired in for me smart alternator. 5 minute job.
  13. J19WMK
    Wiring IGN Cable for DC to DC Charger - HELP
    Hi everyone, In the interest of saving myself some time and money; Can any help with “piggy-backing” a IGN cable for a DC to DC charger from the fuse box under the dash? Thanks
  14. E
    Renogy DC charger ignition switched live.
    Probably been asked a thousand times, but I'm just connecting the ignition feed. Says in the manual from Renogy, if voltage is between 12.5v- 13.5vdc then it's a Smart Alternator, if it's 14.7vdc it's probably a normal one. I've 2015 T6 Bluemotion 102 non adblue so think Euro 5 and I'm getting...
  15. Dickie W
    Fuse tapping for stage prior to ignition live?
    Afternoon all, I know the upper middle row of mini fuses in the internal fusebox are ignition switched. Does anyone know if there's a slot that will be live when the key is tuned partially and not fully to ignition please?
  16. Mic71
    T6.1 ign/live in the drivers’ door loom?
    Does anyone know if there is an ignition supply feed I can pick up In the drivers door? Because I would like to put a wireless charging base in the top pocket of the door card.
  17. Salty Spuds
    Making USB & 12V sockets ignition controlled
    We have just swapped our phones & the new ones have Magsafe wireless charging. They don't fit into our existing Brodit holders, so this is my plan:- Modify the existing Brodit holders to take a Magsafe wireless charging "puck" like these...
  18. Dave512
    Ignition Staying On [Resolved]
    Hi All, I'm having an issue that has just started regarding the ignition. Basically when I turn the key to the off position and remove the key everything stops as should be. However, after a flicker on the dash the ignition is showing as on; as if the key was in position 1 for ignition. The...
  19. G
    CTE D250SE ignition cables
    Hi all, I am currently trying to fit the CTEK D250SE to my T6 and I’m hoping for some clarity on the ignition cables. I have a dual purpose flooded lead-acid leisure battery and am wondering do I fit the black ignition cable to ground and the red to the fuse board or is that only for AGM...
  20. Petegoss
    Ignition Live capacity
    How many components can I safely power from one ignition live feed? Currently I have tapped into my radio ignition live with a 5A fuse This then goes to a small fuse board/block whigh is then distributed as the ignition live for: 300W roof light bar 2x 54W rear light bar 2x Heated seats Is...
