induction hob
  1. J
    Vangear
    Hi, I’m looking at getting the Vangear Modular pod, which has a hob,sink,fridge and wardrobe (the link is below). Would anyone know if they are any good? Quality? Functionality? Are they easy to install? I have a T6.1 panel van at the moment so I’m looking to see if this would be a...
  2. B
    Induction hob recomendations
    Hello, has anyone got an induction hob set up in their van please ? Thinking of going down this route on my new build.
  3. D
    Lithium Battery Ah for electric hob
    I have an ex RAC T6 2018 which we a few months in to converting. I’m currently looking at a solar setup with lithium battery but have limited knowledge so after a little advice. Ideally I wanted to fit the battery under the drivers seat as the double passenger seat will be setup to rotate. We...
  4. N
    Sink with inbuilt induction hob?
    I’m part way through my van conversion and have decided to go all electric in the van, as such, I’ve been looking for a combination sink with an induction hob rather than the gas hob. I have only found two on the web so far (one from aliexpress and the other on Amazon). I was hoping to find one...
  5. M
    Ridge Monkey for induction hob
    Does anyone know if there is a Ridge Monkey or SQ Professional style pan that works on an induction hub. I’m struggling to find something, but recon it should exist.
  6. Epic-Rob
    Induction-only cooking setup
    OK so I have been doing some experimenting with induction cooking v gas, as in my next build I am thinking I want to be just induction. But I am getting some weird readings that I am not really sure how to interpret and possibly my Lithium batteries aren’t as good a quality as others. The...
  7. Bryn23
    I Fitted a Induction Cooktop into the Camper
    Well, this has been on my list for a while, i was sick of having to get the old induction cooktop out and set it on the bench up to make a cuppa. I was limited by space and depth, but i came across a suitable cooktop that could be recessed on Aliexpress. I ended up just getting the 800 Watt...
  8. Shoes
    Thetford Induction hob - Alternative?
    Evening all, I'm looking at the Thetford 902 Induction hob but I'm just wondering if anyone has come across anything else that would be suitable as it seems so expensive. It must be fitted in the worktop, I don't want a portable one. Watts as close to 2000w as possible. I'm guessing this...
  9. R
    Single fitted induction hob
    Hi Everyone , can anyone recommend where I can buy a single induction hob fitted (so I can cut into worktop) many thanks
