instrument cluster
  1. Eddie Sutherland
    For Sale VW transporter highline clocks
    I am having a garage clear out - these highline clocks were bought to swap out my T6 start-line ones but have bought a T6.1 now so not required. £150 These can be posted at buyers cost or collected from Exmouth Devon.
  2. antony.charnley
    EVEREST-VW Digidash, Digital Dashboard, Virtual Cluster: Supplier / Installer
    www.everest-vw.co.uk Everest VW is a small, family-run company born out of a passion for improvement. Antony Charnley, the company's founder, is a trained Industrial Design Engineer holding a Masters in Product Engineering. Highly qualified to provide detailed product evaluations and...
  3. BigYoeKing
    T6 virtual cluster from aliexpress
    Hi i just want to show virtual cluster for vw t6. the wait was long , but today it arrived from china. the original cluster must be disassembled and the motherboard from it used for the new ones. installation is quite simple, although a bit rough. I had to cut out a piece of plastic...
  4. S
    Instrument cluster Fault
    Hi, After some advice please. I have recently purchased a t6 manual, 5 speed, High line, 2019 it had a damaged engine so purchased it and had a company refurbish the engine this was fitted and the van starts and stops perfectly. However it has a fault that has now been diagnosed as a cluster...
  5. meza
    Can’t set time/clock on MFD - left hand button not working
    I’ve got a problem setting the time on my T5.1 The left hand button on the speedos doesn’t do anything, so I can’t get into clock set mode. The right hand button works - in so far as holding it down clears the trip mileage. Any ideas? I’m 11 hours and 40 minutes early for everything currently.
  6. Stevemcc
    Image in cluster change
    Hi all ,anyone know if it is possible to have this image in dash on t6 and what the coding is if possible thanks
  7. P
    Cluster 32-pin connector data
    Is there a t32 dash cluster pin data list on here
  8. K
    T6.1 highline clocks retrofit
    Hi, Does anyone knows T6.1 highline clocks part number? Can someone share? I know there is strugle for fitting second hand units, but still would be good to know part number. Kind regards
  9. Coombears3
    T6 Speedo Cluster
    Hi all, This has probably been answered in another thread, but I am struggling to navigate this forum. If the answer already exists, please post a link to the discussion. Can anyone provide a part number list of speedo clusters that will work in my van please? I am looking to upgrade mine...
  10. Pedro20001
    T6.1 upgrade from startline to highline dash clocks, can it be done?
    Evening, can a startline spec dash clocks be upgraded to highline ones? There are several for sale around £100 and would like the better display between the tacho and speedo. Obviously it would need the mileage corrected but can it be done?cheers
  11. K
    dashboard dial backlight issues......
    Hi - am a tad perplexed....... the backlights on the dials are not always illuminated. When I turn on the ignition they come on and the dials are illuminated, when I start the engine they go out, although the needles are still illuminated red. When I turn the light switch on to side lights...
  12. Garv
    For Sale T6.1 OEM Instrument Cluster Dials
    Brand new genuine OEM Instrument, Cluster, Dials Delivery Miles only Selling due to Digital Dash fitting Removed from T6.1 Highline Will need coding to your vehicle What you see in the photo you will receive Open to sensible offers Happy to post at purchasers cost
  13. B
    Sold Dashboard panels / vents
    Full upper dashboard trims consisting of driver & passenger vents, speedo surround, open storage above glovebox & centre stereo surround/vents. £75 collection from Bolton or courier at buyers cost.
  14. H
    Dash lights on after key removed
    The dash lights on our T6 camper (conversion) stay on when the key is removed. The van won’t start either and had assumed it was a flat battery but don’t understand why the dash lights would stay on with the key removed. Any advice as this makes me wonder whether we have a different issue...
  15. 1
    Upgrading Dash panel insert MFD
    hiya can anyone help with any information regarding possibility of changing the clocks, speedo, in a startline, t6 to a highline dash clocks, (one with temp gauge) i have read a few people asking but no one seems to answer, apart from to plug a app, in to get a temp gauge, which i would rather...
  16. M
    Instrument cluster update?
    Hi, I've got the latest 3D instrument cluster on my T5.1. it all works great, but I've noticed that the graphic of the van does not show when the tailgate is open? the light etc still comes on in the van and thus I know its not anything wrong with the switch or mechanics. Is there anyway to...
  17. N
    My hydro-dipped version of the Comfort Dash.
    Fitted the Van-X Comfort dash but wanted to extend it right across the dash, to include the screen surround, the centre panel surround and the instrument binnacle. Stripped the parts out and had them hydro dipped. Really pleased with the result which gives a full flow of gloss black across the...
  18. Andyman
    Dimming lights and switches
    Evening all Just noticed today in OH T6 Caravelle The dimming wheel next to the lights switch doesn’t seem to do anything Previously it would dim the lights in footwells and doorcards and the red lights on various switches Also noticed that the electric window door lock and electric mirror...
  19. S
    Dash light don’t illuminate
    Hi guys my dash light on my t6 66 plate don’t illuminate only the numbers The dials do When I go into direct sunlight they brighten up and in the shade they dull down again Never used to do this
  20. S
    T6 instrument cluster glass replacement
    Does anyone know if the T6 instrument cluster glass in front of you can be changed? I’ve got a small crack in mine and I’m being told that you can’t get the glass separately although I think the glass can be removed, been looking to see if I can find someone that can replace it? Unless someone...
