I’ve searched the forum, but don’t see anything to answer my latest question.
I’ve bought a Wolfbox G900 dashcam / rear view mirror. Research on here showed that I needed a bracket to go between the wolfbox mirror and the bracket on the screen. I’ve gone to fit the wolfbox and the bracket is...
Hi all. I wanted to remove my rearview mirror, which has a sensor behind it and some wiring going in. I wanted to replace it with a wolf box g900 dashcam. It has an adaptor plate so that it can be fitted to an existing stalk (rather than rubber straps holding the mirror in place over old one)...
I`ve had my T6 startline for a few months now and assume it had a business pack. It has a rear view mirror with a power button and a green led light. As it had a bulkhead and no windows in the rear doors, what is it`s purpose ? The wipers aren`t automatic and neither are the headlights so can`t...
Hi all.
I’m sure I’ve read the fix for this on here somewhere before but I just can’t find it again now.
My van has a mirror type reverse camera. It started to only come on intermittently when reverse is selected. I’d say 95% of the time it won’t come on but the lights on the mirror start to...
I have driver's memory seat so when i switch position or open with different key the side mirrors are adjusting accordingly to the settings. However the rear view mirror does not. There is no option to save position because it looks like there is no motor inside. I know that in other VAG...
Just a word of warning which will hopefully prevent others from having the same issue.
My T6 (T32, Class 7) was fine on the MOT no advisories but failed as I don't have a rearview mirror in place!
I put privacy glass in the tailgate (it had no glass before) and I can barely see out of the...
Hi there,
I have a rimless mirror (7E0 857 511 G 9B9) for a T6 (and not a T6.1!) which I bought new, by mistake, for my T6.1.
It won't work in the 6.1 because of the different can-bus protocols in the two variants - but it will work if you have a T6!
Included is the bezel with the hole for the...
What's dangling from your rear view mirror??
I've got a lei that used to smell of washed cotton, now smells of wet dog, and a Break Fluid Coffee Co air freshener that used to smell of coffee and now also smells of wet dog....
And the source of the wet dog smell (although I also contribute)...
I have a T6. 1 and wondered if a T6 rear view mirror would fit a T6. 1? I'm slowly getting used to my van but would feel more comfortable with a RV mirror. Thanks in advance.
Rain and light sensor (RLS) and automatic anti dazzle rear view mirror circuit diagram
Also see associated Data Bus wiring diagram for more details on the LIN bus connections
https://www.t6forum.com/downloads/data-bus-network-wiring-diagram.65/
I'm thinking about getting a replacement rear view mirror that has a reverse and dash cam built in.
My STD radio won't allow factory rear view camera unless I pay hundreds of pounds just to get it played about with and that's without the camera hardware. So that's the reasoning behind...
Hi, I have a 2017 T6 converted camper. I have decommissioned the dashcam but since then the engine won't start (no power at all!). I have back tracked and everything appears to be where it should be. Could my immobiliser have stopped the engine? Thanks in advance.
Hi, hope everyone is doing well in these weird times?
I was thinking about getting a mirror dash cam for the van. I don't have a dash cam at the moment and like the idea of a camera behind to help parking and reversing. Does anyone recommend a good make and model? I've looked on Amazon and...
Hi Guys,
I'd really like to get rid of my rear view mirror from my full bulk, windowless panel van, it's a bit of a distraction and is pointless.
I read a few threads that mention that the light sensor on the back is used for auto headlights and HBA on the T6 but I'm not sure is this is the...
Removed the rear view mirror from my MY07 Highline T6. The bulkhead has been installed from factory and thats how I am keeping it.
The rain sensor sits above the mirror and I assume the other sensor is for auto lights.
The sensor on the mirror itself is for auto tinting the mirror glass at...
Fitted the new cab light unit from @saxoboy. Works a dream. Only thing now is I’ve noticed my auto headlights are not working correctly - they’re just on. I think the sensor is behind the rear view mirror area where I would have been. The only thing I’ve now found - having had a look, is the...
Hopefully this is the correct sub forum.
Due to the fact my van started as a panel van with a bulkhead all I have on my windscreen is a plastic half-sphere where the rear view mirror should be. If I buy a mirror does it attach to that sphere somehow or is the plastic on it removable? I tried to...
OK so I was loading some carpets into the van yesterday and knocked off the rear view mirror.
It's not broken but I'll be buggered if I can get it back on. I can see that there are four clips on the back of the mirror but it seems impossible to reattach it.
I did manage it once somehow after...
