kw suspension
  1. K
    BMVS Edition Suspension - 5k Miles Review
    So it’s been 5,000 miles since I drove down to BMVS and had their BMVS suspension fitted on my T6.1. The van is a kombi LWB with the OVANO drawer system fitted I would suggest I carry around 250kg at all times in the rear, increasing to well over 6/700kg at times. When loaded up there is no...
  2. J
    ST-X Coilover Part-Number
    Hello, Done all the searching etc and it looks like these are the coilovers to go for on a mid budget. I nearly pulled the trigger on Stance+ until I saw a picture from a member on here where the rear springs were fully compacted… Although I have seen the SSP ones on Heritage parts centre and...
  3. AshHT6
    Whining noise (like the wind) after installing coilovers? Damage to driveshaft or bearings or something else?
    Hi all, I installed some stx coilovers the weekend with the help of youtube. I've always done the brakes on my vehicles but never done suspension work before. I'm sure I've installed everything correctly and the van drives so much nicer with no bangs or knocks etc... But.... I'm sure I can...
  4. monkeybusiness
    Sense Check - Time to replace shocks/springs
    I've been quoted 5 hours to install a KW V1 setup on my T32 at a VW/German specialist. That's install and tracking. Seems a lot. Maybe not. What say you?
  5. Leemondo12
    Sold T28 ST X Coil Overs
    Hi All, I’ve just removed my STX Coilovers from my T28, I got the bug for wanting lower and have ended up with SoLow Low fitted :cool: These coilovers were fitted in December 23 and have covered less than 6000 miles, mostly motorway miles up and down to Aberdeen. I have cleaned them all up...
  6. Indigrey
    Sold KW V1 coilovers for T32
    Taken off my van as I've just sold it. They were supplied and fitted by CRS about 2 years/20k miles ago and so are still in very good condition. They give a great ride quality and a nice adjustable level of drop. Supplied with KW toolkit. Some of the grub screws on the rear adjusters have...
  7. Polle
    Caravelle !! ST X or ...I?
    I wanna lower my 2015 Caravelle ! its aT 30 ! Had Vogtland -50mm springs on it with the original shocks . measured it and yes ,it was 50 mm ! Can i lower it wth this springs and the Koni shocks ,or should i go for the coilovers ST X or Koni/H&R ? CSR ,what is the best option ? I want just a...
  8. T
    ST X pictures and opinions please :)
    As per title. I’ve searched and have seen a few posts, but interested in getting pictures of st-x wound right down. Current distance from centre of the wheel to arch 400mm, if you know yours with the STx that would be great - appreciate vans have different weights. At the moment, I think its...
  9. dave_b
    Sold STX T30 Suspension
    £700 Collection in Newquay or we agree postage costs. Rear spring seat has a little imperfection where the spring didn’t quite seat correctly but just cosmetic.
  10. dave_b
    Sold STX Coilovers
    I'm going full Swamper, so I'm selling the STX kit, it is only a few months old. No pics because it is still on the Van, will be removed within a few weeks. WITHDRAWN
  11. dave_b
    STX vs Koni Actives
    Which will give the most comfort? I have been told two different things, so thought I would raise a poll to get some forum answers. I’m having the STX raised to max height this weekend from their current setting which I’m guessing is -60mm I will hence have great back to back comparison on...
  12. Eli
    Who’s got what suspension
    You may have something that isn’t listed so let me know and I will add it to the list
  13. dave_b
    STX coil over and ride height comfort
    I have STX coil overs fitted and the ride height is about -40mm. If I raise the ride height by 20mm will it give a more comfortable ride? Pics to show current ride height.
  14. Veedubd
    4Motion 4 Wheel Alignment after lowering with KW
    Hi Guys, hoping for a bit of advice regarding 4 wheel alignment following having had fitted @CRS Performance a set of KW STX coilovers, today i took van into local Hunter 4wheel alignment place, front camber is out both sides but more on drivers (sorry no printout) castor bang on toe needs...
  15. ellyp81
    KW ST-X vs. Stance+ coilovers
    Hi all Does any one have photo of a t6 t28 fitted with the stance + or STX Coilovers? I’m interested in how they sit, different heights etc Thanks
  16. G
    ST coilover front spring compression
    Hi, live done a quick search and don’t think it’s been raised? i am in the process of fitting ST coilovers, I’ve had them a while but just got round to fitting them. is it normal for the smaller of the springs on the front to be fully compressed? Even before fitting the coils are close together...
  17. S
    Creaking - Rear lower spring isolation rubbers
    I've recently had some noises (squeaking/creaking type) coming from rear of van when turning or going over speed humps etc. Had a look underneath and both rear spring lower rubbers appear to have worn out and the spring tail is rubbing on the raised lump of the wishbone Van is about 12k miles...
  18. DCC
    KW or H&R at 60-65mm ?
    I’ll keep this short and sweet, what would ride better kw variant 1 at their lowest or H&R set at the same height ?
  19. Mike Dean
    T6.1 fortana red - Project Large.
    I'm back (nearly) after selling my Reflex T6. It was time to have a new van built, so I spoke to Oli at @BognorMotors :thumbsup: After a few days of consideration, which in reality was about a year in my head, we came up with this T6.1 fortana red - Project Large. Starting point was to pick...
  20. Samro
    Snapped spring on KW1
    Snapped spring on KW1 coil overs . Only done 6k miles, most of which have been lightly loaded. Most van has carried is about 600 kg. All being dealt with very smoothly, but a bit annoying nonetheless! Anyone else had quality issues with KW1?
