led bulb
  1. burnsy79
    Strange THQ LED headlight issue
    The Mrs was very generous and bought me a set of THQ V1's with the LED bulbs all round for my Christmas. I eventually had them fitted in January and love them, all working as they should. A week and a bit ago I noticed that the full beam on the passenger side headlight was flickering on and...
  2. nigelcro
    Edd China - You Tube
    Edd has just posted this Changing the headlights on his T5, and the legality of replacement bulbs. Interesting.
  3. J
    Front Fog Lights LED Upgrade
    Does anyone know if LED upgrade for the Front Fog Lights are MOT compliant? Been looking on a reputable supplier of Transporter parts and they don’t have any warnings about MOT compliance, they do warn about LED bulbs in their aftermarket headlights so I’m assuming they would do the same with...
  4. W
    Do led bulbs damaged the polycarbinate reflector.
    Hi chaps. Has anyone had damage to their headlamp focusing lens when using after market LED bulbs? I am not sure if the scorching was there before due the halogen bulb or these aftermarket LED bulbs have caused the damage.
  5. C
    LED resistors - that work please?
    so I fitted LED DRL bulbs. I fitted the resistors and all was fine with the can bus error. But recently, one of the resistors has failed. I searched my emails to try and find where I got hem from but can't remember. I'm now on my 2nd set from amazon and neither have worked. the first ones...
  6. The Flying Scotsman
    Black area with LED bulbs
    I just noticed a dark area in my headlight beams. It’s the first time I’ve drove in the dark since fitting my new headlights with LED bulbs. I’m sure I read somewhere about being able to rotate the bulbs to get rid of this. Is this the case? I can’t find the post I read about it and there’s...
  7. A
    Aftermarket headlight issues
    Hi all just a quick question, I have recently upgraded my 19 plate T6 headlights to after market led projector lights with sequential indicators, the DRL bar acts as the sidelight but it doesn’t dim when the switch is turned to sidelight position ? Only when on headlight position, I have...
  8. G
    Poor FM/AM signal
    Afternoon all I'm in the process of fitting a new Alpine head unit, with the engine running the FM/AM signal is virtually none existing. Turn the ignition off it's fine, I've narrowed it down to the headlights coming on. I've recently fitting the THQ v3 headlights along with the LED bulbs. Has...
  9. 993porky
    THQ V3 Bulb adjustment
    Hi everyone I have recently fitted THQ V3 headlights and really pleased but I’m not sure everything is right as when I have lights on I seem to think they are bouncing, it’s when in traffic jam an nudging along behind other vehicles I always think when looking at vehicle in front of me that my...
  10. L
    Glowing number plate led lights?
    I noticed last night that our number plate lights glow In the dark, they are on really dim, has anyone else had this problem?
  11. Macmain12
    Illuminated bulb warning
    Hi Another small issue has arisen, im getting the bulb warning light, and the passenger side indicator is clicking fast, but yet there are no bulbs out, does this require plugging in VCDS, would this help to find these types of Faults. i have been toying with the idea of getting a New VCDS...
  12. C
    Sold Transporter HQ LED Canbus H7 Bulbs New Unopened
    Transporter Hq H7 Canbus LEDs Un opened, brand new. £68 from THQ Can do them for £50 posted
  13. nigeltreves
    LED Numberplate bulbs
    Has anyone got any recommendations or a Link for LED number plate light bulbs?
  14. S
    H1 LED Canbus bulbs
    Hi, I've replaced my headlights for my T6 with these Transporter HQ ones. The dipped beam bulbs (H7) are LED and look/work great. However, the best bulbs available for the main beam (H1) as an upgrade when I bought the lights were Nightbreaker H1s. Although these are only used when I need to use...
  15. j4ckal
    Most reliable rear numberplate LED lights (barndoor)?
    Just wondering if anyone has tried a few of the different LED rear number plate bulb units for barn doors and if so which would they recommend? Currently got THQ supplied ones and to be honest they've never really worked from new. Been in and out a number of times, terminals cleaned, bent etc...
  16. S
    THQ LED bulbs give uneven coverage
    Hi, after bit of advice from fellow members regarding headlights. I have the V3 DRL headlights fitted on my T6 with upgraded bulbs. Problem is the lights don't appear even when turned on (when shined against a wall etc). Looks like the driver side has more projection than the passenger which...
  17. G
    Sold 12v blank and some led interior bulbs
    Hi, Whilst having a clear out I found a 12v blank and a couple of packs of led bulbs! £5 delivered Pic:
  18. moomin-j
    Sold THQ LED Front Fog Light Bulb Upgrade
    Bought from THQ & used for approx 2 months prior to changing for yellow bulbs. Same as these: https://transporterhq.co.uk/vw-transporter-parts-styling-accessories/vw-t5-t6-headlights/t6-lights/vw-t6-led-fog-light-upgrade/ £25, collect from next weeks T6 Forum meet at Brook Meadows, Sibbertoft...
  19. Pedro20001
    T6.1 H15 LED bulbs not working
    Hi all, I've just purchased a set from xenonsonline as recommended and when I installed the rhs bulb it throws an error code and doesn't light up. Has anyone come across this? I cleared codes with carista but they return. I have only installed 1 bulb not both but didn't presume this would affect...
  20. Barley53
    Sold THQ H7 LED bulbs
    A set of Transporter HQ led H7 bulbs, box opened but the bulbs have never been used. According to the THQ website, they will only fit THQ headlight units (all versions). THQ are currently selling these for £65, I'll post them to the UK for £45 or collect from Royston, Hertfordshire for £40.
