led headlights
  1. C
    Aliexpress oem looks like headlights T6.1
    Hi everyone, I have a 2018 t6 liftface and with halogen headlights. I am looking to update my headlights and I found this in Aliexpress https://a.aliexpress.com/_EuBvXuC The guy said that only works on halogen vans. Please tell me your thoughts. Thank you very much.
  2. hciR
    Found T6 OEM LED HEADLIGHTS
    Looking for both LED headlights to fit a 2017 Caravelle. Cheers
  3. M
    Amber DRL on LED headlights?
    Hello. I have a 2016 t6 with the led oem headlights. I wonder if it's possible to code the turnsignals to act as drl? Like on Audi. Or if it's possible to swap the led that's the oem drl for a amber/yellow color?
  4. BIgben
    T6 Full LED Headlights plug and play, who has them, what are they like?
    So I thought I'd start a thread rather than cluttering up other non related threads or for sale threads. Who has got them and where did they come from and what are your experiences? I know there are some installers who are installing THQ units, there's a few sellers on Ebay that have them listed...
  5. J
    T6.1 Factory LED headlights…no headlight washers
    Hi All, my previous two vans were T6’s with factory LEDs. Both had washers that popped up from the bumper to wash the headlights. My new van, a T6.1 also has factory LED’s but I can’t see anywhere the washers could pop up from. I thought you had to have washers with LED lights? Hopefully it’s...
  6. G
    LED lights too low for road signs
    Hi all. I have had a look around and cant find a clear answer. I have a 2019 Caravelle with the LED self levelling headlights. They work as they should and you see them levelling on start up. As far as head lights go they are very good…..to a point. There is no way to raise them and equally...
  7. D
    LED headlight differences between LHD & RHD
    Hi, forum and t6 newbie, but long time transporter owner here️ Reading through other posts on the subject hasn't answered my question. I'm going through registering a LHD t6 from Germany in the UK and It has oem led headlights. I want to know what part makes them LHD/RHD. Is it the removable...
  8. J
    LED Headlight module vendor
    Hi there. I'm looking to facelift my T5.1 to a T6.1 and I would like to ude the original LED headlights. Where can I get the power modules? I saw a thread by someone who got hold of such a set, and I have PM'ed the gentleman with no luck. Hope someone can help me out. Cheers
  9. T6Plumber
    THQ Full LED Headlights for T6
    Heads up for anyone interested. Looks like these are starting to become available :thumbsup: Link to Insta below:
  10. M
    LED DRL turning off with low beam
    Hi guys, After replacing a faulty BCM with a (second hand) one I am running into a few issues. Originally when I switched my Full LED headlamps to low beam, the DRL LED strips stayed on. Now they turn off and only the low/high beam stays on. I hate this. I have of course copied my original...
  11. A
    Sold T6 LED headlight Power Module 7PP941572AE
    7PP941572AE LED power module Never got round fitting them One missing rubber seal ring Posted £35
  12. C
    Reprogramming LED lights to LHD
    Contacted VW Commercial Cardiff asking if they fit LHD led headlights for me to export my van. They told me for £69.95 they can simply reprogram the RHD lights to point the other way. Does anyone know if this is correct? After tons of research to swap my lights out, this is the first time anyone...
  13. S
    Upgrading H4s headlights to full LED headlights - programming high beams?
    I recently purchased full LED headlight units to replace the factory headlights, which originally had H4 bulbs. These new headlights are advertised as plug-and-play, but the seller mentioned that programming might be necessary for the high beam if the factory units used H4 bulbs. To avoid any...
  14. C
    T6.1 headlight alignment or swap for Europe?
    Hi all, Apologies for this post. I've read a few in the forum but they either refer to T6 or don't answer my query. I'm taking my 2022 T6.1 to Switzerland and have to register it over there. I am aware they won't accept the RHD lights as they are. I enquired with THQ about aftermarket LED for...
  15. Stuiemc
    For Sale T6.1 Factory LED Headlights
    Had some misfortune last weekend which resulted in cracking both headlights whilst using GTechniq W7 Glue and Tar remover. Apparently the acetone in the product reacts with the lens resulting in them cracking. I needed to get the van back on the road ASAP due to having trips away planned so...
  16. The Van Cave
    T6.1 Full LED Plug and Play Headlights Now Available!
    Are you looking for the performance of full LED headlights without the £3k cost of a full OEM retrofit? These new full LED headlights from THQ could be the answer. Full LED projectors for both dipped and main beam offer light output that is unmatched in an after market unit. Fully road legal...
  17. A
    LED beam adjustment screw stuck
    Hey, My headlights - LED T6 - are way to height. It's an easy fix, when the adjustment screw is not blocked... Was able to do right side, but left side doesn't budge at all. Anyone had this before? I opened up the plastic cap which holds the screw. Underneath are 2 plastic gears, that control...
  18. LambethBoy
    Wanted Help. Cover cap for dipped beam (Led headlights)
    Bit of a niche part this. Doing my own replacement of headlamp unit. Can't see to find one in the UK, back order at least two weeks. Hoping someone may know someone that's got one in stock. Part no 9 Part no 7E0998607
  19. Bav
    Condensation in LED headlights
    After a few weeks of the van sitting unused on the driveway, I noticed today that there's condensation on the inside of both my factory-fitted LED headlights. The van was new in Jan 2023, so it's just over a year old. I'm presuming the lights are a sealed unit, so this won't be easily resolved...
  20. Ads_Essex
    Sold H&R ARB Level Sensor Bracket
    I ordered this thinking I’d need it, but it turns out I didn’t check well enough and that the bracket was fitted back when I had the ARB installed. Now the LED retrofit is done, I’ve got this leftover. New they retail at around £50. £25 / £20 to VIP?
