led interior lights
  1. D
    Sold Transporter T6.1 LED Internal lights
    Pair of VW Transporter internal LED lights Only 3 months use. Like new. Part number 7E0947123A £18 posted
  2. M
    touch light irritation
    This is a little thing but a bit irritating - when I switch the power on, ALL of the touch lights come on and I have to go around turning them all off. I was wondering whether a) there might be lights around where I can choose their initial state via a switch on the light perhaps, or b) is there...
  3. Skyliner33
    Do you have RGBWW LED strip lights in your van?
    Do you have RGBWW LED strip lights in your van? Im thinking of installing some colour changing COB LED strip lights in the van, but struggling to find a controller. If so what control unit do you use? Are you happy with it? Thanks
  4. T6Gary
    Apologies for asking again, splicing for led lights?
    I want to add 6 led lights to the rear of my 2017 T6, I was just going to splice into loom so they come on when unlocking and go off when locked. My question is which two of the three wires would I use on the factory plugs? Again apologies for asking this the millionth time but wading through...
  5. A
    Sold T6 Caravelle LED luggage area lights
    £35 posted Genuine, had them fitted in my T6 Caravelle load area. Nice and bright and looks much more modern.
  6. Y
    t6 Multivan interior passenger lights problem steady light at 30%
    Hello. need help. I have a VW Multivan T6 2017. i replaced the bulbs in the trunk with leds and since then the passenger lights have failed. When you open the doors, it doesn't light up. But with the engine running, it lights up constantly at 30%, and the ones in the trunk stopped lighting up...
  7. Ayjay
    LED Interior Bulbs.
    I often knock the rocker switch for the light directly above side door with my head as I go in and out of the van. Also, the passenger side front reading sliding switch and door side headrest on the double seat seem perfectly positioned so that the light easily gets switched on when the double...
  8. tommycj
    LED ceiling lights - White & Red - Touch
    I am looking for some LED ceiling lights which you can change between white and red. Preferably they would also have a touch function I have a single switch which turns on and off my ceiling lights, do you think it would be as simple as changing it for a three way switch? Here is a photo of...
  9. N
    Can I splice in a pair of led roof lights on an existing circuit?
    Sorry if this has been posted elsewhere! I have 4 existing led lights in the roof of my van and want to add in another 2. The pair I have just purchased plug into the unit as per picture below - so the question is can I splice this into the red and black between the other two light fittings or...
  10. 8balladdict
    COB Lighting for Halo Roof
    Hi all. Anyone have any ideas of the best COB lighting strips to use for a halo roof ambient lighting install? Want a full 270 degree continuos surround so probably 6ish meters and ideally strips that can bend 90 degrees on the corners when horizontal rather than ones that need to be...
  11. Andysmee
    LED lighting bars with poptop bed
    Has anyone done a halo roof or bars of led lights instead of the usual downlighters along the sides? I've been experimenting with a flexible led strip we use in the awning before we finish the interior of our pop top install:
  12. Heath1984
    Beware of the wife!!
    Well she's finally done it, after months of whacking the centre (glass bit!!!!) of the touch led lights while shouting these blooding things are crap!! One has stopped working. Bit of a long shot but if anyone has a spare Dimatec Recessed Nickel 18 LED Light touch warm white please drop me a...
  13. X
    Interior LED spotlight recommendation
    Hi all, I am starting to look at adding additional lights into the back of my panel van as I (slowly) convert to some sort of day van. I see plenty people using LED downlights/spots. Any recommendations on specific lights to use? Or rough specs (size, lumens)… I’m not wanting to accidentally...
  14. M
    Interior spotlight comes on by itself
    Hi, I’m a newbie to this forum and also to my T6 only had for about 8 weeks so hoping someone can help me. Noticed just this weekend the interior light above the sliding door has been coming on by itself. Stays on for a while then switches off, but it has happened overnight while parked in the...
  15. Gemini
    Interior reading lights
    Im after some interior reading lights, prefrebly flexi arm ones with a usb input to charge a phone, the only ones I can find at the moment are warm light versions and the wife wants a white light one, any ideas where the best place to get some? Cheers Andy
  16. MORGS777
    2 Wire Looms For Led Interior Lights
    Need to buy 2 x LED light to match originals but can find any 2 wire looms for them ? Will cut ceiling panel so will have matching pair front and rear like my old van. https://www.ebay.co.uk/itm/144523517315?hash=item21a645dd83:g:OuoAAOSwBRViZveL
  17. DaveCrampton
    Mounting leisure led lights in the Shuttle.
    I have a 2017 Shuttle SE. I'm adding six thin LED lights off a leisure battery for nicer, more flexible lighting when sleeping in the van. I don't want to cut round holes in the roof liner, like some I have seen. I was wondering how to mount the lights up high with out having to cut and...
  18. Ragster13
    Sold LED interior lights
    Rear interior LED lights, straight swap and will fit T6, really bright and a simple upgrade. The only difference is there's no manual on or off like the T6 standard one. Selling as pairs or individually and happy to post once payment is received or collect from Leicester or Nottingham. £20 per...
  19. Bazaboy66
    Power board set up with Question
    Hi all, just a quick question regards my lighting, one of the 3 strip light dimmable led is staying on a sim flickering state when turned off, do these need a 12v to lower to stop this happening. It’s been playing up recently and already had a switch changed. It stayed on full power brightness...
  20. J
    Led spotlight install help!
    Does Anyone know how to wire led spots in place of the interior lights?! I want them to run off the leisure battery and turn on/off with the doors opening/closing. I've got it so that: Pos 1 on switch - both lights permanently on Pos 2 on switch - both lights permanently off Pos 3 on switch -...
