Hi all, my T6.1 has just failed its MOT on rear numberplate lights. Both bulbs have been replaced (at £48 a pop, grr) to no joy. I can’t see any broken or linked cables nor can I see any obvious earth points.
Anyone any ideas?
My number plate lights don’t work with the lights on.
When I open the tailgate, for the few seconds the latch is energised the number plate lights come on then go off.
Any thoughts or suggestions are very welcome
How do These come out on a 2018 t6 tailgate t32 model
No screws but don’t seem to want to budge with a trim tool either and don’t want to break them if fixed from rear or are they just stuck in and I just need to be more forceful.
Trying to fit led bulbs to them I recently bought
Just wondering if anyone has tried a few of the different LED rear number plate bulb units for barn doors and if so which would they recommend?
Currently got THQ supplied ones and to be honest they've never really worked from new. Been in and out a number of times, terminals cleaned, bent etc...
Hi all, having trouble with led number plate lights failing. Over the last year I must have had 5 start to flicker then fail. Its a 2021 t6.1 with barn doors. Any advice is very welcome!
I've just found this thread a bit too late .
I bought the LED lights below (X2).
If you want them free send me a message and I'll post them to you. Would like them to be used!
Hello,
On our 2016 T6, we have just removed the roof and therefore the 2 ceiling lights (we will replace this with LED ceiling lights which will be connected to the secondary battery).
The problem is that since we disconnected these ceiling lights, on the dashboard there is the "bulb"...
Evening all,
Discovered today that the one of the rear licence plate unit is not working 100 % as it showed up a warning light on the dash.
The bulb which is in an aftermarket unit is the led type and as it seems to be on its way out, would this affect the auto light function?
As it seemed...
Is it possible to swap out the T6 tailgate number plate lights for LED’s
Is this something that can be swapped out? I have noticed it can be done on the barn door version but can’t find LED upgrades for the tailgate version.
Good evening all,
can I ask if anyone has had an issue with replacement rear license bulbs, I have replaced the standard ones for led.
However I have had 2 sets that I have fitted in 12 months but they either flicker or when you tighten them in they go off. I have just fitted another new set...
I've converted my barn doors to a tailgate with LED lights. But I have a orange warning for bulb out on the instruments.
VCDS scan showed no fault codes.
If I go into 17-Instruments and go into measured values, what should I be looking for? The only concern I've found is "Status on input...
