light bar
  1. T
    No reverse lights
    Hello! So basically I installed an auxiliary 18W reversing light underneath the rear bumper and now have no reverse lights. I connected the positive to the rear left tail light's reverse feed (pin 2 green/black if I recall correctly) and put the ground to a chassis bolt, not the tail light's...
  2. Roodedoo
    light bar full beam tap
    Has anyone had experience tapping into pin 8 - high beam - with H4 headlights to activate a light bar? With lights on dip, it still reads 2v. I'm more of a mechanic than an electrics guy, I just wondered if that was enough to activate the relay - which, of course, I don't want. I just got a...
  3. S
    Cricklade van with aftermarket switch behind indicator
    This could be a needle in haystack q, but anyone able to any clues what this switch might be to ?
  4. G
    LED trailer tail-lights
    I have VW trailer wiring on towbar and led lights on boat trailer. The warning symbol comes on with "check left tail light". I know this is triggered by led lights and vw sell an adapter to rectify , but it is quite expensive. As all my lights are working correctly on van and trailer when...
  5. Strettyp
    Tailgate spoiler lightbar
    I've had a search on here and on Google but not seen one of these and wondered if it's a thing I would like to add some additional rear lighting for reversing as I find the light from the reversing lights a bit puny, and also so that when on a campsite etc I can have some additional light on...
  6. Rob The Daddy
    Roof Light Bar Recommendations?
    Hi Everyone, Can anyone recommend a light bar and brackets to go on top of a T6 Transporter please? Last weekend, I drove to Danby Castle for a mate's wedding, and had to drive through the Yorkshire Moors, last Saturday at midday in thick fog; and in the evening at around 8.30pm (again in...
  7. Snowdawg
    HOLD:52” Curved LED Light Bar (22,500 lms)
    Hi… I’ve promised the wife that I would create a bit more space in the house… so I am having to list my ‘curved’ light bar. Bought to originally mount to a roof rack in a Swamper style, but ended up having a pop up fitted instead. Can be roof mounted, rack mounted or bumper mounted (due to the...
  8. J
    Lightbar: Canbus or not?
    Hej there experts! So happy I found this forum. Now to my first threadstart and question. How do I know if my T6 needs a canbus connection for fitting an led bar as additional headlight? Mine is a multivan from 2016. Is it perhaps only the t6.1 that has canbus connection for the headlights, or...
  9. Petro
    T6.1 LED high beam signal feed for auxiliary lights (led bar)?
    In the old T6 you could get the feed for auxiliary lights from the LED's and probably halogen too from the wiring harness behind headlight unit. However, the T6.1 has much fewer wires coming to the LED headlight. Anyone know can you get the feed from one of these, or how is it done on the T6.1?
  10. SAF1981
    Scotchlok Or Posi Taps Supplier?....
    Hello, has anyone know a supplier or have a supply of either scotchlok or Posi taps that I can use to wire in some led bumper reflectors into the tail lamp looms? I can't seem to find a local electrician or supplier that has the scotchlok with the female seals.
  11. David Deere
    Adding Spotlights To T6 With Factory Fit LEDs
    Just a note for anyone else trying to work out which wire you need to splice into, to get spotlights working on a T6 that has factory fit LEDs, it's the thin white/black one and not the thicker white/black one on pin 8. There is another post here that said pin 6 was the low beam and pin 8 was...
  12. Dannyb6467
    LED Light bar....anyone got one fitted??
    Hi folks...Concidering fitting a light bar or similar to give me plenty of light for working. Has anyone got any photos of where you fitted it / them please? Thanks, Dan
