What part am I missing here in the photo? It's the top part of the spring coving & it's missing from both sides of the closing mechanism for each door - not even the spring is on the drivers side. Both doors rattle & I think this is the culprit. The pin aligns into the part that's missing.
Little guide as this is well covered online, but hopefully you'll find this when you need it.
Peel off the rubber cover on the edge of the door. Inside is a torx bolt. Whilst gently pulling the lock barrel outwards, unscrew the bolt until the barrel comes away. Don't completely unscrew the bolt...
