lowered handbrake
  1. J
    Handbrake lowering kit
    Had our sportscraft swivels in for a good few years now and the lowering bracket that was supplied is bent into all sorts of shapes through years of use , also the cover doesn't fit so is in a box somewhere. The handbrake now points in an odd direction and I'd like to remedy this . I see thq...
  2. Wrigles
    Sold Single Swivel Base & Handbrake Lowering Bracket £50
    Sportscraft Single Swivel Base T5/T6 (new unfitted) and used handbrake lowering bracket.. I don’t have the fixing bolts for the swivel.. but sure these can be found.. £50 the pair.. collected from Manchester.
  3. Dellmassive
    Sold Kiravans VW T5 T6 Handbrake Lowering Kit
    Kiravans VW T5 T6 Handbrake Lowering Kit was fitted on the van for three weeks - then removed. £45 + £4.50 shipping +++++++++++++++++++++++++++++ +++++++++++++++++++++++++++++ https://www.kiravans.co.uk/products/handbrake-lowering-kit
  4. B
    Handbrake lowering. What’s this?
    Just trying to install a handbrake lowering kit so I can fit swivel seats. Watched videos online but none mention this extra wire and plastic blob screwed to the inner plastic between the handbrake and drivers seat. Anyone have any ideas? Thanks.
  5. JimDiesel
    Handbrake lowering kits
    Hi all, I’ve added swivel plates to my seats and now need to lower my handbrake. Which is the better of those available currently? I know the brackets are pretty much what they are but it’s the gâter/shroud/cover which I’m keen to get feedback on. Someone I know had the Kiravans one and the...
  6. M
    Sold Kiravans Handbrake Lowering kit
    Hi I have one of these lowering kits for sale. Some slight marks where it was bolted in, but they are covered by the plastic cover when fitted Kiravans VW T5 T6 Handbrake Lowering Kit Looking for £35 collected from Burgess Hill (RH15) or can post for an extra £5
  7. W
    Handbraking lowering - adjusting original plastic trim?
    Can it be done - re lowered hand brake. Have searched through this forum (awesome information everywhere here - I end up down a rabbit hole and picking up other tips), thought I had seen at some point someone saying - heh if you cut here and there the old trim will fit around the lowered...
  8. N
    I have a Kiravans hand brake lowering kit sitting on a shelf. Its been fitted but instantly taken off as I hoped it would make the double passenger seat easier to rotate (but it doesn't) Same as this: Kiravans VW T5 T6 Handbrake Lowering Kit £50 delivered
  9. A Bridge Too Far
    Sold Passenger seat, with swivel base, locker, drivers swivel,handbrake bracket and floor blanking screws.
    Hi, we converted our bench to two captains seats when we bought the van, however we now need to change back; I have the following available which is what is needed to fit a single passenger and a swivel for the driver; VW T5/T6 Inca passenger seat (we paid £299) used only with THQ seat covers...
  10. C
    Sold 2 x Swivel Single Bases
    I have 2 single swivel seats for sale. One is a Rusty Lee version that I bought new last year and have probably moved it 3 times since. £125ono Second is a Rib which I believe is a drivers side. Bought 2ñd hand and never fitted. The extra rails are for extra height from what I understand...
  11. hunta
    Handbrake spacer
    Fitted swivel seats today but ran out of adjustment on the handbrake when lowered. Has anyone solved this with a spacer and if so can point me in the direction of an appropriate part?
  12. Andysmee
    [GUIDE] How to fit a swivel base and handbrake lowering kit to a T6
    Quick guide to fitting a swivel to the driver's seat, in this case it's a RIB driver's swivel and I used the handbrake lowering kit instead of the raising shims. First remove the driver's seat off the base, and remove the handbrake as described here: Thread '[GUIDE] How to remove the driver's...
  13. I
    VW T6 Sportscraft handbrake lowering kit
    Hi All, Needing some help. Has anyone fitted a sportscraft hand brake lowering kit? I have attached the bracket to the handbrake but when I put it back on the rear bolt fowls on the seat base. Am I doing something stupid? I have taken a photo. It won’t go in because of that rear bolt Any...
    Lowered handbrake on lowered original VW bracket on a T5 fitted with a Sportscraft seat swivel. This is the seat swivel designed to take a leisure battery in the seat box.
