lowering suspension
  1. M
    Sold T6.1 T32 Eibach Adjustable Sport Comfort Lowering Springs £150
    Selling my Eibach Adjustable Sport Comfort Lowering Springs for a T6.1 T32. I bought these new about 3 years ago and they have done approximately 6k miles. Removed them as I have gone for new coil overs. These are suitable for T32 load rating and for all models including 4Motion. They are a...
  2. Y
    20” 8.5J tyre rubbing
    Hi all, Apologies in advance as I am sure this has probably been covered to death. I’m new to the transporter scene having got myself a T6 (t30) in the summer. The van came with 20” wheels, staggered set up (8.5J and 10J) and 275/40/20 tyres all around. I’ve recently had Solow ‘Low’...
  3. J
    Wanted SoLow or B14 Komfort for T6 T30
    Hi Guys & Girls Looking for the above if anyone is looking to sell? Cash waiting Thanks Jack
  4. W
    Rear adjuster delete with Bilsteins
    The rear of my van sits too high compared to the front. I’ve got a set of B14’s fitted but the rear adjusters don’t look like they’ll budge, they’re currently wound about 2/3 of the way down. Before I buy replacement and wind them further down, does anyone have any pictures of B14’s on a kombi...
  5. davek
    Sold H&R rear springs for T5-T6
    These have been on my van, T6 T28 for less than 100 miles, before i swapped them out for slightly longer ones just to lift the back end slightly, (personal choice). They are in near perfect condition, slight bit of paint rubbed off on the tight coil ends, that all. I'm asking £50 for the pair+...
  6. F
    Too low for wheel alignment
    Hi A mate with a T6.1 running 21” wheels and lowered is shredding inner front drivers side tyre but the wheel alignment place said they can’t fit their equipment on to the wheels because it’s too low. Anyone else experienced this problem and what was the solution. Cheers Kenny
  7. W
    Lowest on 255/45/18 ?
    Hi, I currently have a set of coilovers which I could take down 90mm at the front at their lowest setting. Realistically, even if I swaped to a set of Solow low am I really going to be able to run lower than this without dropping the tyre size? I don't want to do this because I have a T32 and...
  8. A
    tyre fitment, 18 steels on a lowered van
    Hi, I'm new here, and recently bought my first T6. The van is currently sitting on what I think are Judd T311R 20s, and have a 255 35 tyre: The fitment is very close, and whilst the van looks cool, and I've had no issues with rubbing etc, I've decided I just can't live with the ride. Im going to...
  9. G
    Kombi on 20” - Ride Height Suggestions
    "Hey fellow VW enthusiasts, I'm seeking some advice on choosing the right ride height for my new T6.1 SWB. After snagging some LV 20-inch alloy wheels, I've set my sights on lowering it to achieve that sleek look we all love. I've got CRS in mind for the job, but I'm torn between two options: a...
  10. S
    Sold Westfalia detachable towbar ball with higher ball for lowered vans £50
    Westfalia detachable towbar ball After having my van lowered 80mm plus my caravan no longer sat level when towing using the factory supplied Westfalia tow ball. After much research and asking sellers to supply measurements I bought this ball which sat higher and made the caravan sit level. I...
  11. CJW
    Sill protection real world experience
    Morning all. I’ve recently had the CRS treatment on each corner. Looks and feels WAY better (will add to the CRS review thread once I’ve tried it fully loaded). The stance is wider, so the wheels are likely to throw particles up towards the lower sills of the van. I plan on keeping the van for...
  12. Deviant Tubs
    VW Stealership - New Top Mounts at 17K miles!!
    OK so here's the short of it - T6.1 DSG 22 plate. 17k miles. Koni Shocks and Evoteck Springs added c/o CRS when van had less than 100 miles on the clock. Lowered 50mm. Running 19 inch Brocks on 245/45/19 Uniroyals. Been very happy with the ride etc. Developed a bit of a clunk/snap/crackle and...
  13. G
    20” alloys - how’s the ride?
    Looking to change from our current 17” Devonports to a larger alloy on our T6.1. The current price drop at Leighton has me looking at 20” LV-1’s… Our suspension setup is a ‘Definition Kit’ from CRS. Not sure of the drop but not ridiculously low as we drive a lot to the Lake District, Snowdonia...
  14. J
    Front wheel 20x9J ET35 offset
    Hi All, first time post so apologies if this has been raised already. Purchasing my first T6 and looking to lower it by 70mm and fit 20” rims. Does anyone have experience or an opinion on fitting front 20x9, ET35 and rear 20x10 ET42. Is this config likely to cause any issues i.e rubbing? Thanks
  15. P
    Planning T6 conversion - do I need to lower the van
    Bought a Startline with business pack but it seems to sit too high. 16 inch wheels. They look better when lowered but is it worth the cost? 18 or 20 inch wheels plus tyres and lowering over £2000??
  16. M
    Thoughts - Driving on Track - Transporter T6
    Okay, so this will be unique topic. Did anyone try driving on track? I recently bought Transporter T6 short wheelbase panel-van (no seats at back) for my motorcycle riding. And ever since I played Assetto Corsa with Multivan 400hp I want to do this in real life. I'm not going to do any racing...
  17. B
    How low / how much front clearance for kerbs / car parks?
    Can anyone with an lv-s chin / splitter or other alternative give me an idea of how much clearance you have at the front and how low you’ve gone on suspension pls? I sometimes do multi storey car parks and most worried about the ramps. I was thinking about 180mm would do it? Anyone got less and...
  18. powell7
    Am l doing the right thing? (Lowering)
    Morning all So I picked up my t28 last week and love it. I have 20's on it and it looks like a tractor on the standard suspension so ordered a set of h&r 35mm lowering springs. I've read lots of reviews and people are mixed with the ride quality after just a spring change. Will 35mm on the...
  19. Tony Abbott
    window wiper problemo
    Hi, I have a front window wiper issue. As you can see from the pictures, both wipers are 2feet in length but when they are active, the dvrs side wiper goes off the window screen onto the vehicle body, any ideas?
  20. dErZ
    Center exhaust scraping on certain speed bumps
    I've got a T6 LWB shuttle running 18" Amaroks on Solow suspension (running at the top so 100mm) its embarassing when I drive to work as theres 2 large long speed humps that kiss the center exhaust box. I've checked and its on the hangers which dont look bent. Has anyone swapped this out for a...
