lowering with dcc
  1. landy
    Coilovers and DCC - what happens without delete kit?
    As title, if I plump for coilovers without a dcc delete kit to start with, with a view to add it later due to funds, what happens? Just annoying bong when key on and fault light during driving? Or is there going be a repeated bonging to drive anyone crazy... Cheers Landy
  2. landy
    DCC and further 50mm drop
    Have DCC on my Velle, running stock 18s. I'd like it lower, been toying with bags but wondering on a cheaper alternative initially. How far can I drop it on springs alone and still have dcc active? Does it need recoding somehow? Could -50mm still work? Aware the dampers will be sitting in a...
  3. T
    Ride Comfort - Standard DCC vs. Lowering coilovers (KW/B14 Komfort)
    Hi guys, I have a brand new T6.1 Multivan 4Motion to be delivered later this month, equipped with DCC as standard. The van will mainly be a family hauler on weekends. Kids and parents. So the ride comfort is the top priority here. Does anyone have experience with both the standard DCC vs...
  4. A
    Lowering Ocean with DCC
    Hi all, looking to lower our 2021 Ocean and have the DCC option. I'm aware the DCC only really affects the dampers and was wondering if anyone had any experience of lowering a Cali with DCC? Cheers, Matt.
  5. Jezma
    OEM Shock Absorbers on back order!
    Hi guys, Maybe some new/useful information to some of you :) Spoke to my local dealership today about acquiring replacement front shocks and apparently there is close to no stock UK (OSF) and in the case of NSF no stock UK/EU :eek: They apparently have NSF on back order but without indication...
  6. JimVee
    Sold Bilstein B14’s front and rear shocks
    Taken the B14’s off my 2016 Gen 6 Caravelle prior to selling the bus. all the bits in the pics, no leaks but usual wear and tear. the sensors are the Dynamic Chassis Control cancel kit and fool the vehicle into thinking the DCC is still fitted (thanks Oli) came off when Bognor Motors removed...
  7. G
    B14s California Beach
    Morning all - can anyone tell me what chassis the T6 California would be built on so I know what coilovers I need? I think the Beach is based on a T30 but not 100% sure! do you need to have adaptive cruise recalibrated after lowering? Also, I’d there something I read about LED headlights...
  8. T6180
    New Bilstein B16 For Dynamic Chassis Control
    All Just seen these pop up the Transporter HQ Instagram page
  9. DC.
    Has anyone removed DCC to get lower suspension? Thoughts??
    So I've got DCC and I would like to go lower on my suspension. I appreciate I can have a 50mm spring drop and DCC is fine (all be it the warranty wouldn't be).... but I would like to go lower!! Has anyone removed DCC from their van in order to get more lows? How did you find it??? I can't help...
