night heater
  1. J
    Night Heater Controller
    Hi everyone. Just picked up our 6.1transporter and cannot get our diesel heater to work. This is a picture of it. Does anyone know what make it could be so I can google the instructions. Cheer Dave
  2. K
    Scotland - Night Heater fitter
    Hi guys, does anyone have a recommendation for a diesel heater fitter in the glasgow area?
  3. T6ChrisO
    Craft‘A’Camper - Mobile Diesel Heater Fitting
    Just wanted to give a thumbs up to Josh at Craft A Camper for fitting my diesel heater yesterday. Josh does mobile diesel heater installations at the comfort of your home. second time I've used him and wouldn't hesitate to recommend him to anyone on here. https://www.craftacamper.com/
  4. J
    Eberspacher or chinese night heater ?
    Hi, new member, so hopefully ok with this 1st post. I have Chinese Diesel heater unit fitted at present and have option to change it to Eberspacher D2. I noticed with the Eberspacher it draws 1 amp on idle mode !! - ie just the 801 Lcd controller active without the heater running. This is...
  5. R
    Diesel Heater Exhaust Position?
    Hi Guys, We have just purchased a VW T6.1 swb, that has a ‘Yulkar’ diesel night heater. We are quite happy with the purchase apart from the location of the exhaust manifold (see pic) The seller who is a time served mechanic and a VW camper enthusiast! Told us that it is located there so it...
  6. T
    For Sale Eberspacher 701 controller
    Eberspacher 701 controller this is the diagnostic model £50
  7. shaiboyuk
    Diesel heater exhaust routing
    Hi all, Currently installing underslung diesel heater, and all going well, but can't find the best routing for the exhaust. Seen some routing it to the centre of van, using the vans existing exhaust channel, but worried fumes will come into van somewhere (of course will install Carbon Monoxide...
  8. ausT6
    T6F Australia
    Saying hi. Hope Aussies are allowed here. All looks good.
  9. G
    Space needed under drivers seat for diesel heater
    I finally got around to installing a leisure battery and a DCDC charger under my passenger swivel which has taken all available space. I had to fit a 12v fuse board under my drivers seat. I’m also going to locate a battery charger and 240v socket there. My question is what room would be needed...
  10. B
    Lavaner Pro night-heater
    I’m looking to purchase a lavaner pro diesel heater but I can seem to find anywhere that sells them.. Can anyone point me I the right direction? Thanks
  11. A
    Diesel Leak?
    Hi Everyone, This morning I came out to use my van and noticed a diesel leak (I think) from the passenger side near the ad blue tank/diesel tank. Upon investigation underneath I spotted what appears to be a small gauge plastic blue pipe that has detached from a clamp on a wider rubber pipe (Pic...
  12. B
    Webasto air top 2000 stc external bracket drawing.
    Hello everyone. This is my first post here. I have just bought a 2016 vw Multivan that I plan to use as a weekend camper. Some of my planned modifications are to install a webasto diesel heater under the car. I am trying to find measurements and drawings, possibly a 3D drawing, for the...
  13. R
    Diesel heater installer - Midlands
    has anyone got any recommendations for. Diesel heater installs in the midlands
  14. B
    Diesel heater blowing but no heat
    No heat from my diesel heater it is running. but not getting any heat any advice would be appreciated.
  15. J
    Night-heater stopped working
    I have a heater under neath the drivers seat that warms on the back of the van. The van is brought from a deal that had custom built it. The controls are camper king. I'll attach photo. I used the heater last night and now when I try to turn the heater on it tries to start for about a minute...
  16. Belly
    Night-heater without a leisure battery?
    Looking to have a night heater fitted, I see it's advisable to power via a leisure battery which I don't have, for the same price as a leisure battery fitment I could buy a portable power bank which gives me a few more options. My question is would this be OK for my needs for the odd overnight...
  17. G
    Powering a camper from a power pack without a leisure battery?
    I’ve only recently bought a Transporter and am now considering the power side of things. I like the look of portable power packs and am wondering if these can be a true leisure battery replacement. Onboard they seem to have many options with regards to outputs, 12V DC, 230V AC and USB A/C. I’ll...
  18. Q
    Diesel hob/heater produces noticeable sweet smell when running however the CO monitor does not go off...
    I finally got one and have installed it successfully. I have tested the co2 monitor with the test button and it beeps as expected. I also inadvertently found out that it works in a real situation when I braked a couple of times when driving and some exhaust fumes must have come in through my...
  19. Skyliner33
    Moving night heater hot air inlet.
    Recently I had a diesel heater fitted to my van. To cut a long story short I was talked out of having it fitted under the drivers seat and so it was fitted coming up through the floor behind the drivers seat. It's further back than I imagined and will get in the way of the furniture units. So...
  20. bmc054
    Night heater - how long to warm van?
    Could anyone tell me how long these take to actually heat the cab etc ? My T6 seems to take forever to warm up on these chilly mornings ,I’m thinking of having one fitted anyway and this could speed up my decision I also like the idea of switching it on remotely so the vans toasty on my early...
