oil cooler
  1. T
    Vw t6 180bhp oil cooler leak
    Hello all, My t6 is passing coolant from the oil cooler, it looks to me like one of the seals/ O rings has failed. Does anyone have a diagram to make sure I order the correct part? Hopefully this will solve the issue as I don’t want to replace the full unit! Vin: VE1ZZZ7HZGH082433 Thanks a lot...
  2. joe_j_barnes
    Oil gooey???
    Hi All, any idea what could be the problem? away camping dad checked the oil and says it’s not right, smoke coming from dip stick tube, called AA advised to not drive but no diagnostic yet advised me to call VW assist, who are now on way to collect. it’s only just on 24000 recently had first...
  3. Bryn23
    Liqui Moly Ceratec
    Just wondering if anyone here has used Ceratec? Im dropping the oil this weekend, before we head off again around Australia and i was thinking of trying some, i used their Diesel additive every second tank during our last lap around aus and i noticed the improvement. Seems to be highly rated...
  4. bmc054
    Oil Cooler Leak
    I have a small oil leak from around the oil cooler on a Euro 5 engine 2.0 litre Has anyone changed the o rings before or have access to the part numbers please? 2015 T6 Thanks
  5. GONA66
    180 Hp Bi-turbo T6. ( Australian Spec).
    Morning all, looking for advice please. Having read previous stories of the 180 bhp model suffering from increased oil consumption etc,etc ,is the latest 2019 T6 180 hp model ,still an issue ? or is all sorted. I've contacted VW commercial and the person I spoke to seemed uncertain , but...
  6. AndyAK66
    Head Gasket
    Hi check oil keeps coming on,dealership cant find a problem realistically dont think they could find thier arse with both hands, checked today neck of oil filler looks like cold beef fat and filler top got white fatty deposit, didnt drive the van for 4 days, started ok then cut out, took...
  7. S
    Should I or Shouldn't I ? - BiTdi EGR worry!!
    I'm about to put a deposit down on my most expensive vehicle yet - a 2016 4Motion 180 T32 T6... And I'm bricking it. I've been doing so much research around the forum and net but can't find a definitive answer on the 180 BiTurbo issue with the EGR. Lots of information on the problem, but only a...
  8. N
    2014 180 Dsg High Oil Consumption
    Hi, just throwing this out there. My 2014 180 dsg starting using oil during its first year from new, topping up between servicing. I do around 32000 a year. Vw said it was well within manufacturers tolerances. Gradually worse and worse over next two years. 100000 miles later, started smoking...
  9. Petehelmet
    Losing Coolant
    Ok so posted a couple of weeks back about my temp gauge beeping and flashing red and indeed as advised it required a small amount of water, about half a cup if that. Since then even though I have seen no signs of a leak I've had to do the same thing twice. So Van was booked in for a service last...
  10. P
    Flywheel bolts leaking!
    My van went for its first service at the dealers last Friday, they phoned me and said I had an oil leak from between the engine and gearbox. They’ve taken the gearbox out now and told me that I have oil leaking from the flywheel bolts and from an oil cooler seal above the gearbox, has anyone...
  11. Z
    Black Coolant [Resolved]
    Hi all, I drive a 2016 TDI250 - love the thing. I’ve done just over 47,000kms in her mainly to and from work and on weekend camping adventures. She’s been serviced every 10,000kms with the last one 1 month ago, where the diesel filter was renewed. 2 days ago I went to Newcastle and back (300km...
