oil leak
  1. L
    Wet Turbo
    Hello today I changed the glow plugs in my CXEB 204 ps and saw a wet turbo. When driving fast I'm leaking a lot of oil. Is it the turbo or the inside of the engine that needs work?
  2. T
    Oil leak but from where?
    Hi I have an engine oil leak coming from under my Van but cannot work out where it is coming from? It appears to be coming from between the sump and gearbox joint, possibly the hole on the sump side to gearbox but cannot be 100% sure. Oil does not appear from any higher than the top of the...
  3. Da Moose
    Clutch Slipping!!
    Hi all, Recently noticed my clutch is slipping, mainly in 4th gear during normal acceleration?? T32 150ps 6 spd manual with only 19763 miles completed. Has anyone else heard of or experienced this??
  4. H
    Identifying Oil Leak
    Hi all, really excited to find this forum - my husband has just bought a Vw Crafter 2010 CR 35TDi2461cc combi 109 and it has an oil leak! He’s tried to find a manual but had no luck. He has identified where the leak is coming (See red arrow on picture) from but, being used to much older...
