I’ve got a December 2020 Vw t6.1 kombi. I purchased it when it was a year old so I don’t know what happened in its first year but I’ve had nothing but issues with the ‘reduce oil level, go to workshop’ warning for the past 2 years.
I have been to my local Vw dealership a number of times and...
Hello
Just came home from work and an Engine Oil Amber light has come up. I've checked the levels and for any leaks and all good.
I have how ever been on a new site and scrapped the bottom of the van a little, again checked and no damage or leaks?
Having read a little says to check oil...
Hi guys
New to vdubs thanks for having me
On way down south when oil leval to high popped up. Anyone else experience this as vw said they have change there oil weights to 5 which expands more and the sensor needs to be change this will be rectified when it goes in for inspection or service...
Hello, my ‘ oil pressure ‘ light is flashing continuously after my T6. 2016 105. Hits 2k revs. The pressure has been checked and is fine. The local garage have replaced a new oil pump, 2 oil filter changes, unblocked oil pick up pipe, 2 x pressure sensors, wire checked. The VW garage are also...
I had an “oil level too high warning “ over a year ago now, went in to VW to get the software update required and it’s been great ever since.
On my way to Scotland this week on the motorway it came On again.
I see a lot of people on here have had similar issues, if my software is up to date...
Has anyone else had an oil warning light come on?
Just had the oil warning light come on and done a check. The oil is right at the bottom of the stick. Anyone else used much?
It's a 204ps with 6,000 miles.
