Hello,
Big fan of Transporters always wanted one since I was a lad! Recently had the opportunity to grab a T6 at a good deal so took the plunge!
(2020 T6 40k miles)
After a few 100 miles had the oil overfill light appear. (I bought this from a friend who advised this light was appearing on...
I've had the dreaded flashing glow plug light for 3 months and been chasing faults to no end and the one fault that's not gone is the oil pressure switch malfunction which have been changed x2 green and brown and oil regulator. also had the sump dropped to check the filter and pump belt all...
Please help ! I have had my 2019 4 motion Komi automatic since new 44k on the clock and converted by Expolria into a day day van lowered,insulated, leisure battery etc cost 70k in total
I am on a service plan and mot with Vw
Just had a mot annd major service and they picked up an oil leak and...
I’ve got a December 2020 Vw t6.1 kombi. I purchased it when it was a year old so I don’t know what happened in its first year but I’ve had nothing but issues with the ‘reduce oil level, go to workshop’ warning for the past 2 years.
I have been to my local Vw dealership a number of times and...
Greetings to you all!
I have had ongoing problems on my T6 Multivan CFCA. When I purchased this van from a dealer, it was drinking lots of oil. It was found to be the EGR issue that we all now know about and since then, my engine was removed, reconditioned (by an engine reconditioner...
Got some codes including 16056 Oil Pressure switch.
Can someone point me at the sensor location?
Some picies of CXHA engine would help.
Kind Regards,
Owain
PS its a CXHA engine.
2 Faults Found:
16056 - Oil Pressure Switch
P164B 00 [01100100] - Malfunction...
Hello, my ‘ oil pressure ‘ light is flashing continuously after my T6. 2016 105. Hits 2k revs. The pressure has been checked and is fine. The local garage have replaced a new oil pump, 2 oil filter changes, unblocked oil pick up pipe, 2 x pressure sensors, wire checked. The VW garage are also...
I had an “oil level too high warning “ over a year ago now, went in to VW to get the software update required and it’s been great ever since.
On my way to Scotland this week on the motorway it came On again.
I see a lot of people on here have had similar issues, if my software is up to date...
Morning,
I’ve recently done a top end rebuild of a 2018 T6 2.0tdi with 104,500m after a cambelt snap. I’ve had all sorts of issues since doing the rebuild one of which was a misfire due to stuck injectors. This is now sorted.
Now she’s up and running I’ve got an oil pressure fault at idle. So...
Can anyone point me in the right direction to locate the low pressure sensor on a 2016 T6? I'm having a yellow low oil pressure warning light flashing and going to replace the sensor.
Should be the reason as I'd just had a oil service 3 wks ago.
Got an oil level warning today after a cold start. Van has only been in use a few months but 9k miles on the clock.
Dipper is clear of oil altogether. Sorry rubbish photo.
No signs of oil in the floor where I park. Any ideas?
I've had a flashing orange glow plug light for a couple of weeks. And possibly or possibly not related, start stop errors.
Plugging in Carista reveals 16056 fault code, which after googling, seems to relate to an oil pressure sensor.
Hoping to rule out some quick fixes before...
