oil temperature
  1. E
    Does anyone know which is the sensor that indicates the temperature on board a t6 2.0 biturbo?
  2. G
    Oil temp
    Hi guys New to vdubs thanks for having me On way down south when oil leval to high popped up. Anyone else experience this as vw said they have change there oil weights to 5 which expands more and the sensor needs to be change this will be rectified when it goes in for inspection or service...
  3. Chessbo
    Coolant temperature readout obd2.
    Hello everyone. Does anyone know what temperature sensor the OBD2scan is reading from correctly? I am driving a 2017 T6 110kw. I noticed a few months ago that my gauge of my coolant was very slow to warm up and in some cases did not even reach 90. My mechanic told me my thermostat was probably...
  4. Mkgolfnutters
    Oil Temperature
    Hi Can anyone shine a light into what the oil temp should be I was away for the weekend travelling down the A11 just thought I would scrool through the Dis and I noticed the oil temp was 101c I think that is a little high as I was only cruising at 65-70. Does anyone else check their oil temp...
  5. Hinsley
    Oil Temp Gauge Vs MFD readout
    Having not had the van long, when I was out on it’s first decent long run I noticed the temp gauge sits at 90 but when flicking through the mfd it was saying 105. This has become a habit now checking the differences. When starting cold the gauge is at 50 (zero) and gradually warms up to sit at...
  6. Graeme Mckay
    Startline - Is There A Temp Gauge?
    Happy new year to everyone out in forum land. I’ve noticed there is no engine temperature gauge. I've looked through the manual and played with the limited display. It's a startline that's been converted. Is a temp gauge to fancy for this model? First vehicle I've owned without one if so. What...
  7. bigwig74
    engine oil temps
    so what engine oil temperatures is everyones T6s running as i think mines running warm ,its a normal 102bhp . im getting up to 103 on average motorway trips ,when if i trash the life outta my caddy it only gets into the low 90s
  8. Rick
    Oil temperature
    towed our 1500 kg caravan to Cornwall and our oil temperature reached 111 degrees C at some hills Does anyone know if this is an acceptable reading and what is the highest it can get too without causing a problem T6 kombi t32 lwb dsg 150 hp tow vehicle
  9. mhill
    Thermal Efficiency
    I've noticed over the past couple of days that the engine is completely unable to "warm up" unless your running at over 60mph. This evening a trip back from my nans doing no more than 30 for 37 minutes over 16 miles (lots of very thick fog) I got home parked up and there was ice on the bonet...
