paint issue
  1. kombisnaps
    Dealership has mullered my paint - advice on recourse?
    So van went in to tackle my leaking drivers door, and has come back with what I can only describe as a scouring pad wash. The swirling and scratches is insanity. To top this off, I only just had the van detailed and ceramic coated last week. Wondered what steps I should take, as I want them...
  2. GruB
    Help with suggestions - how to disguise / cover the damage
    Dear all, Took the van into the paint shop today. Caught the bus home. Nearly home I get a call - he is not prepared to attempt to paint the bumper as he cannot get the paint match correct. It will look bad so not going to try. He used his paint scanning machine and then a different one from...
  3. R
    Stain on paint?
    Hello, any ideas what this is? Looks like an oil stain or something. Everyone I wash the van it remains. Thanks
  4. Griffywest
    Peeling paint/rust along roof drainage channel above windscreen
    Hi, new to the forum and I was looking for some advice on a 2019 highline kombi. We’ve experienced a minor leak in the centre roof console and I think I have narrowed it down to the windscreen seal. On further investigation I noticed the paint in the channel along the top is peeling and what...
  5. Andysmee
    Pop top gel coat polish, courtesy of DOC
    Anyone tried it?
  6. 8
    Paint Issue - too fussy?
    I purchased a 2022 T6.1 that I knew had a little paint done (had viewed and asked for a couple of dings / scratches to be sorted by what seems to be a very careless previous owner). The work was completed and looked fine when I picked it up, however now I’ve had it a week or so I’ve noticed a...
  7. 8
    Strange paint issue on wheel
    Have recently bought a T6.1 Kombi, which had 18’s in immaculate condition when I picked it up. Yesterday I noticed a few marks where the paint was missing on one of the fronts, and today its worse again. It hasn’t flaked, but looks like something has splashed and burned through the paint! Has...
  8. M
    Paint Finish / Quality on my Van
    Hi, I've bought a 2019 T6 - 24k miles in Candy White, might be a bit of a lemon. Previously a work van I went into this with a view that it was in fact a work van that will have had some scrapes and paint and wont be perfect and that not an enthusiast owned sports car so was willing to look past...
  9. L
    Rust on drivers door sill T6 2019 (not seal)
    Hi all, I’ve just bought a T6 2019 plate, 29k converted camper. Gave it a polish over the Easter weekend and noticed a small rust patch/ line on the drivers door will, and on the bottom of the door (see attached image). A friend has suggested sanding it back then re-spraying, which I feel...
  10. paulfr
    Any Paint advice?
    Bought a new back bumper,because mine is Knackered!AA van yellow,but i've got this Metallic Blue one.Shold i just prime over the top a few times and put the yellow on,or Rub the whole thing down/prime and paint.......i'm hoping for the first answer!Also can you get fillers to cover the parking...
  11. DazS
    Spoiler with blistering issues
    I bought my van in September this year, 72 plate. I had some optional bits added including these rear barn door spoilers. Back in October, they started blistering, so I took it back to the outfit that fitted them for me, which was where I bought the van from also. They kindly swapped them for...
  12. S
    Cali Roof Corrosion - VW's current warranty stance?
    My 2017 Cali Beach has a dreaded bubble on the roof. Anyone know if VW are still entertaining warranty claims for this? Interestingly it shows the tape they put around the edge works - the corrosion has started in the 3mm gap where the tape joins! Let's hope there aren't any more joins further...
  13. Strettyp
    Rust under rear registration plate
    I bought some pressed metal licence plates to replace the ones that came with the van, purchased new from inchcape VW commercial in Manchester When I took the rear plate off I found that there was a line of rust and a few other spots and bumps - the van is 4 years old and while the 3 year...
  14. Indigrey
    Front edge of sliding door battered by chips!
    Noticed this whilst washing the van the other day. It's a 21 plate and I've had it since new so I know it's not been in contact with anything. I can only think it's sticking out into the wind enough to get battered by stones from the front wheels. Has anyone else had this problem? I presume VW...
  15. 5n0wb0mb3r
    Powdercoat Peeling on Side Bars
    Afternoon All, I had some black trapezoid side bars supplied and fitted by a garage 9 months ago, the coating has started peeling off at the fronts. The manufacturer has said they wont do anything, its because I don't have mud flaps, I don't want them. Can anyone recommend a spray paint /...
  16. Salty Spuds
    Rust around side door handle
    I found some rust spots & a bit of paint bubbling under the side door handle yesterday. Nothing major. Our van is Oryx White & there isn’t a touch up available for it due to it being pearlescent. The rust is under the door handle so pretty inconspicuous. My plan is to remove the handle, clean up...
  17. B
    Swirl marks on black van
    I‘ve recently purchased Transporter T6 on a 19 plate from a main dealer. On both of the days when I took it for a test ride, and when I collected the van, it was wet and overcast. I have since noticed when the sun is out, that the van, which is a black metallic colour, has shadowy swirls in the...
  18. teamfly
    Dent removal ? Paint damaged
    Looking for advice on dent removal please . Cutting grass yesterday & mower picked up a rock & hurled it into side of van . About a 1cm diameter dent , paint is through to metal ( like a rock scrape rather than crack ) . Local dent guys I tried said no can do as paint broken . I could live with...
  19. J88arv
    White haze following paint job
    Hi guys, Ivy van was damaged by a garage when they reversed it onto a ramp smashing off my wing mirror and damaging my whole side….. Had the work done but I can see what looks like a white haze?? Anyone able to give me an idea of what it is You will see it below, only at certain angles...
  20. Mwcard
    Roof Spoiler - paint bond failed!
    Hi all, Fitted barn door rear spoilers several months ago now. The bond has been strong for most of that time but noticed today that the spoilers have both come loose. I used Sikaflex 221 and followed all instructions. Is it common for Sikaflex to fail in such a short time? Not...
