panel-van floor
  1. Ragster13
    Sold SWB P/av Rubber Mat. £100
    Factory load mat for a van fitted with the metal bulkhead as it trimmed on the corner behind the front seats to follow the bulhead trim, this is done at the factory. £100, located near Syston Leicestershire
  2. pugdturbo
    For Sale SWB T6.1 P/V Rubber mat, £100.
    Putting some seats in my 6.1 so the genuine rubber floor that came with it is for sale. All fixings included no holes, no rips or tears. Has had a bench a or tool box or something on it by the previous owner, these mights recover in time, not sure. Open to offers hence the markings.
  3. DanW81
    Found Genuine SWB single slider non kombi rear rubber floor liner
    I don't suppose anyone as this flooring for sale. Looking to replace the ply flooring in my pv. I have screenshot a pic from one that was sold from this forum from another user. I hope this OK to do. Cheers Dan
  4. P
    Wanted Lwb kombi/ply floor
    I’m looking for a lwb single slider floor I can trace around to cut a new floor. Mine was a panel van I’m converting to a kombi. Thanks. Doncaster/Goole area
  5. T
    For Sale Kombi Rubber Mat, SWB Twin Door 2+1. £100
    Removed from a T6 SWB with twin doors. Only taken out as van was converted into a day van. In great condition, and cut outs for a 2+1 setup. Collection preferred due to size. £100 collected. Thanks for looking
  6. W
    Would this rubber-floor clean up?
    Cleaning
  7. HoopDub
    Wanted SWB genuine rear floor, no cut outs single slider
    I am looking for a new or near new genuine load area floor, rubber type from a non bulkhead single slider without any seat cut outs. Long shot i know. Cheers
  8. B
    Sold T6.1 SWB OEM Rear Rubber Floor - Single Slider - £250
    Removing the rubber floor from my T6.1. The van is only 4 weeks old and the rear floor is immaculate. SWB, single slider. Will come with floor fixings, bolts etc. Collection only from Swadlincote DE11. £250
  9. T6_MOF
    Found T6 OEM SWB single slider rubber floor with no cut outs
    Hi All, after the above if anyone can help? Bedfordshire/Hertfordshire area or East London is preferred. Thanks!
  10. J
    Wanted 2+1 OEM SWB Rubber floor single slider
    Hi everyone, I’m looking for a rubber floor as above. Either with cut outs/uncut. Based in Exeter.
  11. D
    Sold P/V rubber floor LWB single slider £175 ONO
    I’m just about to start a conversion and have this I’ll be removing. It does have a couple of small tears in as highlighted. Located in Herefordshire Close up of the damage for ref
  12. K
    Keep OEM rubber load floor or remove and ply line/insulate/sound deaden/carpet floor??
    Hi! I'm in the process of sound deadening, insulating and carpeting my T6. We are using a 'reputable' conversion specialist and they have advised me to keep the OEM spongy rubber floor in the rear without bothering to add any insulation or sound deadening underneath as it does an ok job as it is...
  13. C
    Wanted T6.1 SWB rubber floor, single slider.
    T6.1 genuine rubber floor single slider, ideally new or nearly new. With no cutouts if possible, but would consider others. Located in Newcastle area, willing to travel depending on location Thanks
  14. K
    Sold T6.1 SWB Panel Van rubber floor. £200
    I have for sale OEM rear rubber flooring out of 6 month old 6.1 SWB. It’s going in for camper conversion next week so will be removing the rubber floor. I also have brand new factory coils, they have been removed to lower and factory grills also brand new. Please message if interested in any...
  15. Ragster13
    Sold SWB P/V Rubber Load Mat, Un-cut, £320, Located Leicestershire
    Load mat for a single slider, just removed from a new van, it will come with lash downs and higher side step> The mat can be cut to suit Kombi's, twin sliders ect, will fit all short wheel base vehicles T5 onwards, located in Leicestershire, or in Birmingham (I work there) £320, 2 available at...
  16. Ragster13
    Sold LWB Single Slider PV Rubber Load Mat, Step, Lash Downs. £280
    Just removed from a brand new van, Rubber load mat for single slider, comes with the deeper side step with LED lights and lash downs. Located in Leicestershire or Birmingham, I'll add photos tomorrow. £280 OVNO
  17. Craig.
    Wanted T6 OEM rubber floor LWB single slider with no cuts
    Hi all, I am after a normal OEM rubber cargo area/boot floor. LWB, single slider, don't mind if it does or doesn't have the holes for middle Kombi seats but no holes for rear rear seats. No folds or bends in the rubber. Dirty is fine of course. Closer to South Wales the better :) Thanks
  18. thebuzz555
    Sold LWB Load Mat Single Slider. £150
    Put a ply floor in my van so this is no longer required Genuine VW Load mat for LWB single slider It has been cut around the bulkhead brackets, shown in photos Slight tear underneath, see photo I have all of the fixings to go with it This will be collection only from Chatham, Kent, or I...
  19. N
    Found Twin slider rubber mat
    Is anyone selling a rubber mat for the cargo area to suit a twin slider, either one from a Kombi with a triple seat or one from a Panel van (no bulkhead). Closer to Yorkshire the better!
  20. T
    For Sale T6 T6.1 1 SWB rear single side door load mat (aftermarket)
    I have for sale a T6 SWB rear single side door loading mat. 5mm thick with anchor cut outs. £20 located in Derby. Thanks Tom
