pioneer audio
  1. T6_MOF
    Sold Pioneer SPH-DA160DAB Headunit
    Hi all, Got the head unit i had in my Caddy for sale, it’s the Pioneer SPH-DA160DAB model. Really good little unit and i had no issues with it. No longer needed in my T6 as I’m happy with the OEM unit i have. Looking for £150. Facia included but NO WIRING HARNESS. Everything in the pictures...
  2. M
    Pioneer SPH-DA77DAB
    Hi just wondering if anybody has one of the above radios fitted? i was thinking about this one as it appears to have (correct me if i'm wrong) all the leads that i should require. welcoming your feedback
  3. revdecal
    PIONEER AVIC F88DAB
    I'm trying to download a map update from Pioneer but frustratingly it is saying I have to download a toolbox app to do so. The problem is, it is a windows application and I have no access to Windows, only Macs. Has anyone found a work around for downloading an update from Pioneer?
  4. The Flying Scotsman
    Fitting new head unit need some help please
    I’ve fitted the pioneer head unit my wife got me for Christmas and I’ve got a few questions. I’ve got nearly everything all hooked up and working. Just the DAB Ariel to fix to the windscreen and cables to run for that, the mic and rear camera. I got the full kit from Chris at the Van Cave and...
  5. Forrest4799
    Aftermarket headunit upgrade
    Well the vw radio is playing up more than ever and becoming unusable so been to get a price today for upgrade the choice is Kenwood DMX7722DABS or Pioneer SPH-DA130DAB. The Kenwood is wireless and cable with Apple play, Pioneer is cable Apple play only, both units allow current steering wheel...
  6. L
    Pioneer VREC 150MD
    We have had this unit installed as we wanted reverse camera to supplement our reverse sensor. The dealer recommended this unit as it doubles up as dash cam for a little more money we got two things rear cam and dash cams front and rear. The unit when in rear view my wife finds the image is very...
  7. D
    Pioneer Stereo Stop Start Issue
    Had a new stereo-fitted Pioneer SPHDA160DAB) it's driving me insane every time I stop at lights (only when stop-start is active the stereo restart) odd times it doesnt go off but most of the time it does It's very frustrating especially if using sat nav. I am not sure how this has been fitted I...
  8. G
    Opinions on Pioneer h/u?
    Anyone fitted a SPH-EVO950DAB? My OEM unit is starting to get really glitchy so maybe time for a change? This Pioneer ticks a lot of boxes, mainly that it won't look like a Tesla in the front as the unit looks similar size to the total size of the original unit corner to corner. I've had...
  9. L
    Pioneer avh-a3100dab fitting in a T6.
    Will a Pioneer avh-a3100dab fit in a T6, I have the basic DAB radio with SWC? Has anyone installed one of these, if it does fit I take it that it will need a loom and adaptor facia? Thanks.
  10. M
    Pioneer + & -
    I'm in the process of fitting some speakers, which is the positive, the little plug or the big? Thanks
  11. M
    Dash USB port dead after Pioneer fitted.
    Morning all Since fitting a pioneer sphda230dab the usb port in dash is now dead on my t6 does anyone know how to get this back working please
  12. paradigm
    Audio upgrade options
    Hi all, I’ve been getting a series of quotes from various suppliers, I’d love to know please if anyone has direct experience of any of these set ups, the subs especially: Audio upgrades Basic Level 1 Upgrade: Hertz DSK-165 £119.99 VW Speaker adaptors £19.99 Phoenix Gold ZR10P £249.99 (On...
  13. Hobbo
    Removal of dash USB/Aux-in socket
    Hope someone can help with this- I was having problems with the USB socket connected to my Pioneer head unit. The female USB was loose, when I took the plastic plate off the USB cable came out completely and is stuck somewhere in the dash. I can just about see it, but no end of fishing...
  14. Wayne196
    VW T5.1 2015 Stereo Upgrade Reverse Signal to Head Unit Issue
    Good afternoon all. I have bought a Pioneer SPH-DA360DAB car stereo head unit. I've trial fitted the unit with Incartec VW group quadlock to ISO radio adapter harness, with CANbus ignition and an upgraded set of Vibe Audio 8 inch door speakers and tweeters with no issues. On my previous radio...
  15. S
    PIONEER SPN-D160DAB Problem.
    I have had the Pioneer SPN-D160DAB professionally installed in my 2018 T6. Some time when I start the van the unit turns off and then restarts after about a minute. Also the steering wheel controls won't work, but not at the same time as the unit turns off and the on. The software has been...
  16. P20
    Pioneer 9200 ~ any good? (As no Kenwoods are available!)
    I was wanting to fit the Kenwood 8020, but they’re all sold out. Spoke to a local installer who has recommended the Pioneer 9200. Clicky linky thing to Pioneer 9200 It looks like it does all the same. Installer reckons it’s better on DAB reception (it’s getting a new external aerial too) and...
  17. peteslack
    Dash USB port fuse number/location
    Checking out the wiring in my 2017 Highline and discovered the harness for a dash USB port, a purple plug. Question is which fuse should it be wired to in the fuse box ? The plug reads no voltage including when the engine ignition switch is on. Also the original head unit has been replaced...
  18. J
    issues with Pioneer SPh da 120
    Hey everyone, just bought a t5.1 with pioneer sph da120 headunit, i cant get the bluetooth to work, and the setting are greyed out. Iv taken it out, and cant see anything obvious, also cant see any cables marked up as park brake, as i thought that may need to be grounded, Any ideas?
  19. Y
    Sold Pioneer AVIC-F9880DAB Headunit
    Originally supplied and fitted by Slidepods. Includes dash surround and the loom that I removed from my van. This is a good quality sat nav unit - I only removed it as a I decided to go with an Absolut5 set up with a Kenwood headunit. £495 £450 Collection from GL51 preferred.
  20. Superowls
    Sold PIONEER head unit & reverse camera, Apple car play & Android Auto
    Selling a PIONEER SPH-EVO62DAB head unit Its come out of my T6 & comes with all the wiring loom, facia plate adapter, reverse camera, microphone & other cables (think it's the leads to connect to mfsw) dab aerial (this has been on a windscreen so may need replacing as it may not stick properly...
