plenum chamber
  1. Constalation
    Plastic section across bonnet top
    Can anyone help. I need to remove the plastic piece that the wiper arms go through to check the heated screen connections. How does it attach. Can't see any screws. Any help most appreciated
  2. D
    Trim under front windscreen
    What is the plastic trim under the front windscreen called and how do you remove it? I'm needing to lay cables from the battery to a B2B charger inside and can see a grommet to put the cables through behind it....
